Freeze Protection Cable - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-31-2013, 05:54 AM   #1
Freeze protection cable
Hello ,
I need some advice,
I will install a freeze protection cable on my pipe.I will like to know your opinion on
the best place to put the cable heat thermostat.In the installation instruction we can read" the thermostat
should be placed on the coldest end of the pipe". The problem is that if I put the thermostat
where my pipe froze last year (see the picture to know where) ... this portion of the pipe
will not be heat , so this portion of the pipe will retain cold and never been heat...
so my pipe had chance to freeze again next winter.
I'm confused .... where is the best place to put the thermostat if you look at my plan?
dave19099 is offline   Reply With Quote
Old 05-31-2013, 06:58 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,568
The furthest location from the home will be the coldest location. Start it there and work backwards.
Old 05-31-2013, 04:05 PM   #3
Rewards Points: 2,108
The thermostat should not even be on the pipe. The temp it should be looking at is the outside air temp... The pipe should have heating its entire length and insulated if your heat tape manufacturer says that is safe to do.
It would also help if you left a trickle of water on the cold during real cold times... Never had a water line freeze on my manufactured home.
Ghostmaker is online now   Reply With Quote
Extending and covering phone cable in closet Dorado Electrical 5 03-28-2013 10:09 AM
Running data cat5 cable in walls fdmillion Electrical 2 01-17-2013 07:15 PM
Community pool house - freeze protection heater? Editingfx HVAC 1 11-01-2011 02:33 PM
What kind of surge protector to get for these items baby327nd Electrical 27 10-06-2011 03:35 PM
crispy cable! Why wouldn't a breaker trip? morganhammer Electrical 4 04-05-2011 11:33 AM
