Freestanding Tub Waste Pipe .. - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-05-2013, 10:55 AM   #16
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Originally Posted by adamavis View Post
Thats the bottom of the tub, it's the drain. The metal hose connected to the drain goes to the overflow.
My question is more about the flex hose, The threaded end connects to the drain of the tub. How do I connect the flex hose from the drain to the abs plumbing? Is there a fitting for that like a dishwasher nipple?
I see now.
I would say to see if you can find a threaded ABS fitting that will screw onto the drain and eliminate the flex hose. That flexible stuff looks a little too hokey to me. It seems to be designed so that you don't have to redo any of your current plumbing. I've seen some before kind of like that and they were standard 1-1/2" threads, so a 1-1/2" female - ABS adapter screwed right onto it. Be careful not to overtighten or you will crack it.
Journeyman Plumber
Old 01-05-2013, 11:12 AM   #17
That's what I'm looking for, thanks Alan.
That flex hose is pretty thin, ill go the traditional route.
adamavis is offline   Reply With Quote
Shower waste pipe to toilet waste microbar Plumbing 2 05-17-2011 04:24 PM
How to clean a PVC waste pipe from rubber washer remains? sukhenkoi Kitchen & Bath Remodeling 3 03-04-2011 10:10 PM
Is yellow polyethelene or polyphenol gas pipe now the preferred gas conduit? MarkSilber Plumbing 1 09-18-2010 12:10 PM
Sewage smell from internal waste pipe jellybean11 Plumbing 3 03-17-2010 09:10 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 11:09 AM
