#1 |
Freestanding tub waste pipe ..
I purchased a freestanding tub and there is a flexible hose that attaches to the drain. The hose is similar to a washing machine or dishwasher waste hose.
Do I let this sit loose in my plumbing rough in in the floor? Let me know if you need pictures? |
#2 |
Super Moderator
Yes pictures and a link to the instructions if available---
New members: Adding your location to your profile helps in many ways.--M-- |
#3 |
Doing it myself
I've seen a tub with a drain setup similar to what you are describing. It was one of those walk-in tubs and it had a dishwasher style hose that connected the overflow portion of the drain assembly to the waste portion of the assembly.
If the tub is currently installed, that hose should be connected to something. If the tub isn't installed, usually the drain fittings for the tub aren't installed until it's time to set the tub. Agree with Mike, however. I'd like to see a model # or something at the very least.
Journeyman Plumber |
#4 |
Hey guys, its an aquadis sm-6340
There were no instructions... |
#5 |
This is the pipe I'm talking about.. Threaded on one end...
http://www.alibaba.com/product-gs/55...showimage.html |
#6 |
Looks like that line is for the over flow.
https://www.bathdepot.ca/product/sm-6340.html Strange there's so little info any where on the net on this tub. Go back and add your location to your profile. |
#7 |
Updated location. The overflow already came hooked up.. weird right?
That flex hose can be hooked up like a dishwasher I suppose? Is that to code? |
#8 |
I just figured out how to attach images... ill take a photo of the underneath of the tub and post.
#9 |
Here's the tub...
#10 |
Doing it myself
That IS a walk in tub, isn't it?
#11 |
Nope... can i hook this up like a dishwasher or do I have to find a rigid aystem for it?
#12 |
hello?
#13 |
Doing it myself
Sorry, i'm a little confused at exactly what i'm looking at here. Which end is up? Maybe a wider picture in addition to the ones you posted already would help.
#14 | |
Freestanding tub waste pipe ..Quote:
My question is more about the flex hose, The threaded end connects to the drain of the tub. How do I connect the flex hose from the drain to the abs plumbing? Is there a fitting for that like a dishwasher nipple? |
#15 |
I had a similar situation with a walk-in shower my wife wanted me to install. Some expensive foreign brand with a drain line setup like yours. It's been several years, but I think I used a slip nut coupling. That didn't work at first, because apparently the drain line fitting was metric! I don't think you can bury a slip fitting, but I didn't have that issue. But if I had to do it again, I'd figure a way to replace that flex drain with pvc.
| Display Modes | |
| Shower waste pipe to toilet waste | microbar | Plumbing | 2 | 05-17-2011 05:24 PM |
| How to clean a PVC waste pipe from rubber washer remains? | sukhenkoi | Kitchen & Bath Remodeling | 3 | 03-04-2011 11:10 PM |
| Is yellow polyethelene or polyphenol gas pipe now the preferred gas conduit? | MarkSilber | Plumbing | 1 | 09-18-2010 01:10 PM |
| Sewage smell from internal waste pipe | jellybean11 | Plumbing | 3 | 03-17-2010 10:10 PM |
| Need to support 15th of ABS pipe | irishtimes101 | Plumbing | 3 | 09-01-2006 12:09 PM |
