Framing Nail Went Throug PVC Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-05-2008, 04:07 PM   #1
Rewards Points: 1,062
Question
framing nail went throug PVC pipe
the tip of a framing nail went through PVC pipe and it is nearly impossible to replace the pipe because it is immediately near concrete coming out of the floor. the nail is fastening a stud to a PT sole plate right next to the PVC pipe.
i can take the tip of the nail out but there will be a small hole. am i better off leaving the nail in ? if not, is there some compound i can use to patch the small hole in PVC ? it is also nearly impossible to fit a fernco sleeve over it.
Old 10-05-2008, 04:26 PM   #2
the Musigician
DangerMouse's Avatar
a photo or two would really help here. are you sure the nail went all the way through the pipe? if so, you will undoubtedly end up with a leak, so yes, i believe it will need fixing. lucky for you we have some real geniuses here!
DM
Old 10-05-2008, 04:50 PM   #3
Rewards Points: 1,088
Is this PVC pipe under pressure, or just drain?
Either way, it can be patched via an epoxy compound. You can buy it at Home Depot.
Long term solution is to replace that section though.
handy man88 is offline   Reply With Quote
Old 10-05-2008, 05:08 PM   #4
If it isn't a pressure pipe you are in luck. There is patching material at your local big box stores or local specialized plumbing store.
And next time watch were you aim that gun.....8-}
Marvin Gardens is offline   Reply With Quote
Old 10-05-2008, 05:24 PM   #5
it is not under pressure. just a drain pipe. THANKS GENTS !!
Old 10-05-2008, 07:41 PM   #6
Get yerself some of that Might Putty!
Old 10-05-2008, 08:11 PM   #7
BUILDER / REMODELING CONT
buletbob's Avatar
epoxy will work and also you could cut a piece of a bicycle tub and cover the hole with that and wrap a hose clamp over that and then tighten it.
Old 10-05-2008, 08:33 PM   #8
the Musigician
darn smart thinkin' Bob! simple and cheap!
DM
Old 10-06-2008, 05:43 PM   #9
J Calvin Construction
jcalvin's Avatar
Rewards Points: 150
Put a fernco on it and it won't look so cobbled up. You will have to cut the pipe or the rubber bushing in two to get it on.
Cal
You hired WHO?
jcalvin is offline   Reply With Quote
clipped FINISH vs. FRAMING nail amakarevic Building & Construction 4 04-25-2008 04:46 PM
Best Practices for Framing Nail size jms5883 Remodeling 7 01-31-2008 12:37 PM
framing conundrum: 2" PVC vent pipe going horizontal through 2x4 studs amakarevic Building & Construction 18 01-19-2008 07:47 PM
Framing Gun - Nail Shank Diameter Questions... MoparAutoworks Building & Construction 5 07-03-2006 10:27 PM
