Old 01-24-2011, 10:57 AM   #1
four inch plastic drain pipe through concrete foundation wall
how does on put a 4 inch plastic drain pipe through a poured concrete foundation wall
dan patterson is offline   Reply With Quote
Old 01-24-2011, 11:00 AM   #2
very carefully
broox is offline   Reply With Quote
Old 01-24-2011, 11:27 AM   #3
Experienced
Jackofall1's Avatar
Above grade or below?
Above, carefully drill a series of 1/4 holes following a pattern made slightly bigger than the piece you are trying to fit through, this process will take quite abit of time, the better job you do with the drilling process the nicer the hole will look. Once you done drilling, get the cold chisel out and clean up the edges.
Fit sleeve in and trowel in non shrinking grout to seal the sleeve into the wall.
Below grade, not recommended, unless you use a large core drill, and have access to the outside, to reseal the foundation wall.
Old 01-24-2011, 05:56 PM   #4
Originally Posted by broox View Post
very carefully
COLDIRON is offline   Reply With Quote
Old 01-24-2011, 06:11 PM   #5
I was beginning to believe nobody appreciated my style of humor.
Old 01-24-2011, 06:17 PM   #6
Are you the other half of Broox and Dunn?
Old 01-24-2011, 06:25 PM   #7
That is not the first time I have heard that joke, nor shall it be the last
Old 01-24-2011, 07:13 PM   #8
Civil Engineer
The simplest way to install a 4 inch pipe through a concrete wall is to rent a diamond drill rig with a 4-1/2 inch diameter bit. You drill through the wall with the rig, following instructions furnished with the drill very carefully. Once through the wall, you insert the pipe and fill around it with expanding foam. There are gas and electric versions of the drill, you must use the electric version indoors, make sure you have the proper outlet for the drill.
Old 01-24-2011, 07:46 PM   #9
Plumb or Die!
Use a 4 3/4" bit, 4" pipe has a 4 1/2" diameter, you won't fit the pipe through the hole the engineer recommends. Engineers.......
plumber666 is offline   Reply With Quote
Old 01-24-2011, 07:52 PM   #10
nap
You talking to me?
nap's Avatar
I find it easiest to put it through the wall before pouring the concrete. It's a lot easier to wire a chunk o' PVC to the forms than drill a hole in 6"-8" of concrete.
Old 01-25-2011, 07:15 AM   #11
All kidding aside if you follow post #8, 9. you should be on the right track.
Tough job no matter what.
Old 01-25-2011, 07:23 AM   #12
old guy contractor
tcleve4911's Avatar
Rent one of these
[IMG][/IMG]
tcleve4911 is offline   Reply With Quote
Fix Drill Holes in Concrete Foundation Wall jdusling Building & Construction 8 08-26-2011 11:31 AM
Kitchen Sink Moved - new kitchen sleepysmurf Plumbing 1 08-10-2010 07:38 AM
What is the on the base of the footing for standard circular steel form work for concrete be 12" wall and 36' foundation undation? william lum Building & Construction 1 06-24-2010 07:45 PM
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 01:55 PM
Bathroom Sink Drain (Broken from wall to Ground) bli182nk Plumbing 2 01-11-2009 08:52 PM
