-   -   four inch plastic drain pipe through concrete foundation wall (http://www.diychatroom.com/f7/four-inch-plastic-drain-pipe-through-concrete-foundation-wall-93317/)
dan patterson 01-24-2011 10:57 AM
how does on put a 4 inch plastic drain pipe through a poured concrete foundation wall
broox 01-24-2011 11:00 AM
very carefully
Jackofall1 01-24-2011 11:27 AM
Above grade or below?
Above, carefully drill a series of 1/4 holes following a pattern made slightly bigger than the piece you are trying to fit through, this process will take quite abit of time, the better job you do with the drilling process the nicer the hole will look. Once you done drilling, get the cold chisel out and clean up the edges.
Fit sleeve in and trowel in non shrinking grout to seal the sleeve into the wall.
Below grade, not recommended, unless you use a large core drill, and have access to the outside, to reseal the foundation wall.
COLDIRON 01-24-2011 05:56 PM
Originally Posted by broox (Post 576794)
very carefully
:thumbsup::thumbsup::laughing::laughing::laughing:
broox 01-24-2011 06:11 PM
I was beginning to believe nobody appreciated my style of humor. :wink::wink::wink:
COLDIRON 01-24-2011 06:17 PM
Are you the other half of Broox and Dunn?
broox 01-24-2011 06:25 PM
That is not the first time I have heard that joke, nor shall it be the last
Daniel Holzman 01-24-2011 07:13 PM
The simplest way to install a 4 inch pipe through a concrete wall is to rent a diamond drill rig with a 4-1/2 inch diameter bit. You drill through the wall with the rig, following instructions furnished with the drill very carefully. Once through the wall, you insert the pipe and fill around it with expanding foam. There are gas and electric versions of the drill, you must use the electric version indoors, make sure you have the proper outlet for the drill.
plumber666 01-24-2011 07:46 PM
Use a 4 3/4" bit, 4" pipe has a 4 1/2" diameter, you won't fit the pipe through the hole the engineer recommends. Engineers.......:eek:
nap 01-24-2011 07:52 PM
I find it easiest to put it through the wall before pouring the concrete. It's a lot easier to wire a chunk o' PVC to the forms than drill a hole in 6"-8" of concrete.
COLDIRON 01-25-2011 07:15 AM
All kidding aside if you follow post #8, 9. you should be on the right track.
Tough job no matter what.
tcleve4911 01-25-2011 07:23 AM
Rent one of these
[IMG]http://i172.photobucket.com/albums/w...ailings007.jpg[/IMG]
