Four Inch Drain Changes To Three Inch - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-09-2013, 06:42 AM   #1
Lord of Slums
Rewards Points: 1,974
Four inch drain changes to three inch
Was over a friends house which was built in 2007, and noticed he had a four inch drain pipe running down his wall. It then changed to 3 inch- six inches before it went into the concrete. Is that code? I would have never known you could go from bigger to smaller. Is it common to have the main underground drain as three inch pipe?
mj12 is offline   Reply With Quote
Old 07-09-2013, 07:24 AM   #2
Master Plumber
Javiles's Avatar
Rewards Points: 996
A drain can never be reduced.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 07-09-2013, 04:27 PM   #3
Lord of Slums
Now this is in a very urban area, how in the world did that ever pass inspection?
Old 07-09-2013, 04:54 PM   #4
Rewards Points: 2,040
Why would you assume it was inspected?
You act like no hack plumbing ever occurs.
Ghostmaker is online now   Reply With Quote
Old 07-09-2013, 04:55 PM   #5
In the direction of flow it can be reduced from 4 inch to 3 inch if the 3 inch is upstream.
Old 07-09-2013, 08:59 PM   #6
Master Plumber
Javiles's Avatar
Rewards Points: 996
It wouldn't be reduced it would be increased 2 to 3 to 4 to 6 and so on.
The Following User Says Thank You to Javiles For This Useful Post:
ben's plumbing (07-09-2013)
Is PVC too brittle in cold for drain under a paver patio? BrandonC_1972 Landscaping & Lawn Care 1 07-20-2012 12:18 AM
Paver patio/wall corrugated drain location BrandonC_1972 Landscaping & Lawn Care 0 07-04-2012 11:31 PM
washing machine drain issues lost_punk Plumbing 2 06-19-2012 10:18 AM
Condensor drain Captflx HVAC 6 08-17-2008 10:19 AM
