Old 03-31-2010, 09:07 PM   #1
fountain repair
I am trying to determine if I can rennovate an old fountain my father built many years ago. There first thing I was planning to test was to see if there were leaks in the pipes. Unfortunately I did not realize the pump was not working. Now I am trying to determine what is wrong with a Craftsman 1/2 hp shallow well pump. I have primed it. When I remove the bolt on top I can see water. When I turn it on I hear it buzz but after about 15- 30 seconds it turns off. I am assuming that is a safety to keep it from over heating. I don't know if I should call a plumber to try and fix this pump or whether I am going to have to a new pump installed before I can find out about the pipes. Would appreciate any thoughts or instructions if there is something basic I am missing in getting the pump to work. It worked a couple of years ago when it was last turned on.
melleo is offline   Reply With Quote
Old 04-01-2010, 09:57 AM   #2
Master General ReEngineer
Bondo's Avatar
fountain repair
Ayuh,... The pump sounds like it's Seized...
Take it apart,+ you Might be able to fix it,...
Otherwise, Replace it...
Old 04-01-2010, 12:02 PM   #3
fountain repair
I agree that it is probably seized up. Remove the cover wherever the water enters the pump (most are through the bottom) and check the impellor. It looks like a fan blade and may have something stuck in it, preventing it from turning.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
$1440+ labor only repair on 3 yr. old Goodman unit!?! JMK HVAC 23 05-06-2012 11:45 AM
Choosing a Refrigerator based on Repair Value 1655graff Appliances 5 03-01-2011 09:49 AM
Repair Compounds saggdevil Painting 3 04-25-2010 04:02 PM
What do you guys think of this roof repair job? darsunt Roofing 7 08-21-2009 09:43 PM
Ceiling Drywall Repair Question kennykenny Building & Construction 6 12-30-2007 10:18 AM
