Form-a-gasket - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-19-2010, 09:16 AM   #1
Form-a-gasket
What brand of gasket in a tube would stop a minor leak under the sink?
The leak is where I have attached onto the drain at the wall.
It is a small leak.....a couple of drops or so but aggravating.
I have put in new pipe and new washers but still get that tiny leak.
Does Permatex make something or some other company?
Thanks!
Chuckwagon is offline   Reply With Quote
Old 01-20-2010, 03:50 PM   #2
BIGRED
Rewards Points: 252
Where is the leak at the wall? On a pitted or cracked piece of pipe? Or is it from the threads of a jamb nut on a tubular slip seal? If it is on the threads check the seal for scratches on the inside wall, or check the outside of the drain tube if its plastic. The flashing from the extrusion process may not have been cleaned off your pieces smoothly. If all this is for naught then get yourself some plumbers pipe thread sealant (non-hardening only) and apply it to the beveled faces of the nut and
gasket and between the pipe and gasket and tighten everything up. Let it sit for 5 minutes and then start running the water. You should be drip free. MEG-A-LOCK is a good sealant choice.
Grampa Bud is offline   Reply With Quote
Old 01-20-2010, 07:14 PM   #3
Thanks Grampa Bud.....I will try that tomorrow!
Old 01-21-2010, 06:29 AM   #4
#3 Permitex works too! It seals and won't get hard!
Porky
Porky is offline   Reply With Quote
Old 01-21-2010, 10:24 AM   #5
Porky
Thanks Porky.....I will get a tube of that to use also. I imagine it is good for a lot of things, including plumbing!!
Burner Box Cover Gasket Johnnysan HVAC 8 02-12-2009 12:48 PM
Tank gasket problem firemanter Plumbing 1 01-01-2009 10:26 PM
Weatherhead gasket Clutchcargo Electrical 2 09-14-2007 09:43 AM
Head gasket? DIY? 98 grand prix 3800 papashaq Automotive Repairs 3 03-18-2007 08:38 PM
Replacing air handler - How to fit when form factors are slightly different?? hennyh HVAC 2 11-16-2006 08:23 AM
