Fork Stuck In Kitchen Garbage Disposal And Unjammable - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-16-2012, 11:51 PM   #16
1: Shop vac out the water & Goo,.... or just undo the trap over a pan or pail & drain it.
2: Test the disposer. There is a breaker button near the edge, Push it & turn it on. Even just a moment of hum says its OK.
3. It is attached to the sink by a bayonet ring. The three tubes use a special wrenck, or any screwdriver that fits. Unscrew it (1/3 turn). If the thing is still attached to the trap, loosen the nut & lift it free & away from the sink.
4: Lift off the "splash guard" and reach inside ^ work out the jamming piece. A wrench, or allen wrench will help, forcing it to rotate & free up.
5: Reinstall.
PS: NEVER use Drano or other silly (but dangerous chemicals which plumbers HATE!)
A disposer that is jammed or not run a while will always "plug up" and not drain, but any turning of the grinder (what the wrench is for) breaks the seal and lets it drain!
bareshiyth is offline   Reply With Quote
Tags
disposal , garbage , jammed , sink , stuck
