-   -   Forgot to use Teflon Paste... YES i'm an idiot... (http://www.diychatroom.com/f7/forgot-use-teflon-paste-yes-im-idiot-34608/)
nperkins 12-29-2008 09:47 AM
So I just finished installing my new furnace... Checked EVERY fitting 3 times... Everything was PERFECT! Started filling the system, everything looks GREAT... Except a TINY leak at the bottom most point on the boiler (OF COURSE!)... Because my genius self missed the teflon paste on that one... Is there any alternative that I can use to somewhat cleanly seal it? A putty of sorts? I dont want to use JB Weld or anything like that, but that pipe will make a mess if i have to cut it and drain the entire system back out just to put teflon paste on it... :( TIA...
amakarevic 12-29-2008 10:54 AM
no. just do it all over.
AndrewF 12-29-2008 10:57 AM
Sorry, but the best solution is to re-do it from start. :(
majakdragon 12-29-2008 11:45 AM
Nope. Any "outside" application will probably leak after a short period of time. According to Murphy's Law, it will happen at the worst possible time.
Termite 12-29-2008 02:29 PM
Gotta re-do it. Sorry.
nperkins 12-29-2008 02:39 PM
Wasn't a big deal... Re did it... But now its circulating, and i have a few TINY TINY TINY leaks (Like a drop 1-3 minutes) from 2-3 places.... Think after some heat cycles the teflon paste will work in and seal up?
amakarevic 12-29-2008 02:45 PM
dude, just dope the sh*t out of the male threading, much fatter than you think will fit in the female fitting. the excess will drip off when you put it on, who cares ?
nperkins 12-29-2008 02:48 PM
I did dope the sh*t out of it... Thats why i'm shocked its leaking... and it was fairly tight before i soldered it too... which is why i'm like WTF....
Termite 12-29-2008 03:41 PM
Whoa, we may have found our problem. You said this is a furnace, right? What on earth are you soldering? I was thinking we were talking about gas connections, which should never never never be soldered.
If it is part of a boiler and you have sweat connections that transition to threaded connections, you MUST do the soldering first, then make the threaded connections with pipe dope after it cools off. Or use teflon tape, which can take the heat.
If your soldered connections (copper pipe) are leaking, you overheated the joint, had water/steam in the pipe near the joint, or had an unclean joint. There's no way to fix it, it must be redone.
nperkins 12-29-2008 04:05 PM
I called a friend who is a plumber, and he explained that i probably overheated the joint... I dont have a union there, so I did what he recommended which was take a rag with ice cold water, and wrap the pasted connections while i did the soldering, and that looks much better... doesn't look like the paste is gone this time... And I tightened the fittings much more than i did before... Furnace is refilled and heating back up now... **Crossing Fingers**
Wethead 12-30-2008 05:12 AM
hey ....pssst
Solder your stuff FIRST, then assemble it,
Post a picture if you can
nperkins 12-30-2008 08:00 AM
I cant solder it first, because i was an idiot and didnt put a union lol. And I dont have a pic of the actual joint, but here is the finished boiler. http://nperkins.riotdesigns.com/house/furnace%20006.jpg
