Forced Hot Water Heat - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-17-2009, 03:22 PM   #1
Hi Guys,
I just finished off half of my basement. I need to install heat and was planning on tapping into my lower zone (I have two zones). I have forced hot water. The space is 330 square feet. How much baseboard do I need?
AscolA is offline   Reply With Quote
Old 09-17-2009, 04:31 PM   #2
WaldenL's Avatar
Rewards Points: 268
Wow, there's a loaded question. How well insulated are the basement walls? Floor? Passageway to unfinished half? How hot do you want it? And do you want it hot all the time? It's not just about the SF, wish it was.
Can't help on the sizing, but I would look at adding another zone. Shouldn't cost that much more, and you can then control it separately from the first floor heat.
WaldenL is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Hot water boiler furnace-insufficient heat Nashman HVAC 2 11-06-2011 06:15 PM
rattling pipes when water heat exchanger stops Amilcar HVAC 2 04-06-2009 02:44 PM
