Follow Up Layout- Disposal - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-28-2013, 01:10 AM   #1
Follow up layout- Disposal
I've decided to do some measurements. Then I mapped the layout with dimensions of sink and insinkerator compact. I want to keep the baffle tee as close as possible to the disposal to gain as much open area to the left and under the master sink as possible.
I attached the layout as pdf.
Please take a look at the layout and ask any clarifying questions you may have. Also I will need some code direction. For instance.
Is there supposed to be any elevation change on any horizontalx sections?
Thx for any help or direction in advance.
P.S. I live in San Diego CA
Spinman
spinman1949 is offline   Reply With Quote
Old 08-28-2013, 08:22 AM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 830
I would use the disposal 90 instead of the baffle tee. You would need to lengthen the tailpiece on the left some and loose a little height but the system will be less problematic.
The Following User Says Thank You to TheEplumber For This Useful Post:
Peppe1019 (08-28-2013)
Old 08-28-2013, 06:49 PM   #3
center baffle
E,
I take it you are not a big fan of the center baffle? So unless I am mistaken you are suggesting single baffle. So we will lose about 4 inches height correct? But better drainage from the disposal.
Is that correct? I will redo drawing based on your suggestion.
Spinman
Old 08-28-2013, 06:58 PM   #4
Plumber
Rewards Points: 830
That's correct- you'll loose a little height but your disposal waste will flow past a vertical tee.
Caution- Verify the stub out elevation in the wall at the back of the cabinet. It can limit your options for the continuous waste configuration.
Old 08-28-2013, 07:00 PM   #5
Rewards Points: 2,040
I agree a much better way of doing it.
Old 08-28-2013, 11:21 PM   #6
Thx E and Ghostmaker.
Very helpful from you both.
Stub out is 12 " from floor. 7" above cabinet floor. Disposal outlet is 6 inch down from sink trap. Cabinet is 35" high. Right hand sink is 8 " deep.
So elevation from disposal out to stub should be in the neighborhood of about 12" minimum.
Will that meet code? Main sink will of course tee in lower. Is there a minimum rise required?
Do I use a sanitary tee or a baffle tee?
Spinman
Old 08-29-2013, 07:51 PM   #7
Use a end outlet waste and a flanged tail piece off the big sink.
The Following User Says Thank You to Ghostmaker For This Useful Post:
Peppe1019 (08-29-2013)
Old 08-30-2013, 01:46 PM   #8
Another option please.
Ghostmaker,
If I make the connection to the P trap from the large sink, then I lose all kinds of room in the sink area. Why can't I plumb to the P trap from the disposal and connect the large sink?
Right now that is the way my sink is plumbed. I will make a drawing of the current setup.
Spinman
Old 08-30-2013, 05:45 PM   #9
Plumber
Rewards Points: 830
I think this way is what you want.
This is a kitchen faucet call I went on today.
When I saw this set up I thought of you
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
Peppe1019 (08-30-2013), spinman1949 (08-30-2013)
Old 08-30-2013, 06:23 PM   #10
That is exactly the set up !!
E,
Exactly what I need to do. I attached a picture of the orig setup here.
Now if I can find the heavier duty ABS schedule 40 stuff the original plumbing was done with. Funny thing though. It is all glued together. No cleanout or removable connections.
I am thinking maybe I should put a cleanout fitting at the stub just to make any drain problems easier to deal with.
Regardless I think I have what I need now.
Thx to all that responded. I feel confident now I will end up with a good and efficient draining solution.
Spinman
Old 08-30-2013, 07:06 PM   #11
Thats what an end outlet waste and a tail piece does....
Old 08-30-2013, 08:12 PM   #12
Plumber
Rewards Points: 830
lol- we were all talking about the same thing but the light bulb hadn't come on for everyone.
A picture is worth a 1000 words.......
You remember drawing iso's on drywall, right?
Old 08-30-2013, 08:23 PM   #13
Ghostmaker
Sorry.
I am a dim bulb at times.
Spinman
Old 08-30-2013, 08:33 PM   #14
Plumber
Rewards Points: 830
Originally Posted by spinman1949 View Post
Sorry.
Spinman
It's just a matter of terminology....
Don't forget that you were chating with 3 j-man plumbers. It's easy to use terminology and expect others to follow along.
Now don't start with RC stuff or you'll be drawing pictures for me
Old 08-30-2013, 09:10 PM   #15
Thick Skin
My dad taught me to always place knowledge first.
I would rather acknowledge my ignorance then allow stupid pride to keep me from gaining the best advice available.
I am the jack of all trades type.
Spinman
The age old disposal issue - high drain hyunelan2 Plumbing 12 02-21-2013 05:20 PM
switch to garbage disposal question tard01 Electrical 64 03-30-2012 05:19 PM
Bathroom DWV Layout Problems grymes56 Plumbing 8 05-15-2011 09:00 AM
Water leaking from under disposal/Installing new disposal quadari Plumbing 6 06-29-2010 11:39 AM
Laminate wood floor layout questions nathan.tran Flooring 4 08-30-2008 10:56 PM
