Follow-up From Hot Water Short Supply And Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-22-2007, 10:28 PM   #1
Rewards Points: 1,062
Question
follow-up from hot water short supply and question
hello everyone !
thanks to all who contributed expertise in responding to the mentioned thread.
it did turn out to be a broken dip tube. when i cut the supply line and untwisted the old one, the tube was broken immediately below the threaded top.
Q: now that i have the supply orifice briefly open, was wondering if there is a solution i can rinse the inside with that will take away some or perhaps most of the buildup that has probably gotten caught on the walls of the heater.
thanks,
- a
Old 12-22-2007, 11:03 PM   #2
Master Plumber
Rewards Points: 150
No. Don't know of anything like that except to replace the tank. How old is this water heater? Removing sediment if that is what you are talking about is done by connecting a hose to the drain and flushing the water heater under pressure usually to an outside location, but if you have never done this the drain may very well be plugged up.
jpplumber is offline   Reply With Quote
Ground Main Water Supply? blueboy27 Electrical 17 11-04-2007 12:38 AM
Can water supply pipes be PVC?? i need general help... hallbum Plumbing 5 12-10-2005 01:22 AM
