Follow Up To Dripping Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-18-2012, 07:39 PM   #1
Sycamore Inn's Avatar
Rewards Points: 87
Follow Up to Dripping Faucet
Hi,
You guys were helping me with a dripping bathroom faucet. I turned "only" the hot water valve off last night and have been using the cold water as it was the hot water that was dripping.
I just noticed the bottom of the cabinet in the sink is soaked with water? Why is this? I cannot detect where the water is coming from?
Sycamore Inn is offline   Reply With Quote
Old 11-18-2012, 07:50 PM   #2
Rewards Points: 13,960
Look around the stem of the shut off valve. May need to snug up the packng nut.
Old 11-18-2012, 07:53 PM   #3
Lightfoot's Avatar
Rewards Points: 272
could be the shutoff is leaking a bit. they sometimes do that when they havent been turned for a while. try shutting it off and on a time or two and see if it stops. And occasionally just by tightening the nut holding the shutoff stem by just a little bit will also stop it. If not, it's time for a new shutoff.(that is if the shutoff it what's leaking, but it's a good place to start looking.)
edit: Joe types with more than two fingers, he beat me to it.
Lightfoot is offline   Reply With Quote
Old 11-18-2012, 07:57 PM   #4
Rewards Points: 87
There was a lot of water and the kicker is the dripping stopped. So it must be intermittent - hence the stain in the sink. I'm not sure how a minor leak at the valve could have leaked that much water in less than 24 hours.
Old 11-18-2012, 08:01 PM   #5
Fingers? Hmm I'll have to try that next time.
Outside faucet still dripping watercub Plumbing 11 08-17-2016 11:24 AM
Plumbing 101 Dripping Faucet Sycamore Inn Plumbing 7 11-18-2012 07:51 AM
dripping faucet phelpsmorrison Plumbing 3 10-06-2012 07:36 PM
Dripping Faucet vabear Plumbing 10 04-13-2012 11:55 AM
How to stop dripping bathroom faucet colden Plumbing 14 12-07-2010 11:13 PM
