-   -   Follow Up to Dripping Faucet (http://www.diychatroom.com/f7/follow-up-dripping-faucet-163900/)
Sycamore Inn 11-18-2012 07:39 PM
Hi,
You guys were helping me with a dripping bathroom faucet. I turned "only" the hot water valve off last night and have been using the cold water as it was the hot water that was dripping.
I just noticed the bottom of the cabinet in the sink is soaked with water? Why is this? I cannot detect where the water is coming from?
joecaption 11-18-2012 07:50 PM
Look around the stem of the shut off valve. May need to snug up the packng nut.
Lightfoot 11-18-2012 07:53 PM
could be the shutoff is leaking a bit. they sometimes do that when they havent been turned for a while. try shutting it off and on a time or two and see if it stops. And occasionally just by tightening the nut holding the shutoff stem by just a little bit will also stop it. If not, it's time for a new shutoff.(that is if the shutoff it what's leaking, but it's a good place to start looking.)
edit: Joe types with more than two fingers, he beat me to it.
Sycamore Inn 11-18-2012 07:57 PM
There was a lot of water :( and the kicker is the dripping stopped. So it must be intermittent - hence the stain in the sink. I'm not sure how a minor leak at the valve could have leaked that much water in less than 24 hours.
joecaption 11-18-2012 08:01 PM
Fingers? Hmm I'll have to try that next time. :wink:
