-   -   flux & solder ?'s (http://www.diychatroom.com/f7/flux-solder-s-39153/)
wis_remod 02-25-2009 01:54 PM
flux & solder ?'s
Just curious as to what flux you use/prefer?
Around here (central wisconsin) it is hard to find anything other than Oatey #5 or #95. However, it seems as though a lot of professional plumbers prefer other brands.
Also, what is up with Oatey label about mixing the flux before using. Do they not realize how thick flux is - next to impossible to mix.
Lastly, over the years I have only applied heat to the fitting with solder on opposite side of heat. Some say to apply heat to pipe itself too?
Thanks,
Matt M
AllanJ 02-25-2009 03:20 PM
Play the flame back and forth over both the fitting and about an inch of the pipe .
When you try to apply the solder tot he far side, you are sure that the entire pipe is hot enough when the solder melts.
plumbbum0203 02-25-2009 04:04 PM
1 Attachment(s)
try this brand it easy to mix . You may need to go to a supply house to get this. We vacation to St. Germain WIS in the summer very nice place up there. Love to fish for that Walleye.:eek: The brand of this is NOKORODE
majakdragon 02-25-2009 07:17 PM
I have always used Oateys. When you carry it in a truck box for a while, in high outside temps, it can separate. Normally, I just look to see if it looks "normal". When soldering, I hit the pipe near the edge of the fitting for a few seconds. This lets some heat go into the pipe. I have been told that it is possible to heat the fitting and the pipe still be cold (got my doubts about this). If this happens, the solder could solidify instead of traveling up through the fitting all the way.
PLUMBINGITALL 02-25-2009 07:33 PM
I only use Nokorode. I always heat the fitting and pipe altering between until the solder sucks in to the fitting.
