Old 07-13-2004, 03:33 AM   #1
Darren
Guest
Posts: n/a
Flushing problems
Hi
My toilet isn't flushing properly, the pan fills almost to the top before gradually returning to its normal level.
Examining the toilet and the waste pipe coming from the toilet it doesn't appear to be blocked. We live in a bungalow and the bathroom is extended. As a result the the vertical pipe that comes from the waste pipe is inside. When I remove it, the flush seems to work normally, as if it is something to do with pressure.
I'm stumped, any ideas?
Old 03-01-2005, 11:04 PM   #2
Flushing problems
Flushing really has nothing to do with preasure in a standard application. It works off of the wieght of the flushing water, a bit of siphoning, and the drain pipe has to run down hill enough to keep a steady rapid flow. If the down grade of the drain isn't enough it will cause this type of problem.
Tomm is offline   Reply With Quote
Drywall problems in new house BettyCv Building & Construction 39 05-28-2010 02:51 PM
Are you having ice problems? Grumpy Roofing 27 02-17-2008 04:51 PM
fence problems? composite decks? maml247 Landscaping & Lawn Care 6 03-29-2007 03:10 PM
Possible foundation, door gap problems Jemo Building & Construction 1 02-11-2007 09:43 AM
