Old 12-16-2012, 10:13 AM   #1
Flushing out rust from hot water heater
I have a gas water heater, and i was talking to a plumber about me flushing out the rust from it. I have always heard that I should flush out the rust through the valve at the bottom once every few months.. The plumber told me this is a myth and it doesn't actually help or hurt the unit. I searched this topic online and i see arguments for both sides.
What is the truth? What is the science behind your claims?
Thank you,
~Scott
Toocool100 is offline   Reply With Quote
Old 12-16-2012, 10:37 AM   #2
Minerals in the water are heavyer then the water, they settle to the bottom of the tank.
If the bottom of the tank is covered with hardened up minerals it's going to take longer to heat the water.
Your plumber is wrong.
If you have old steel pipes, or an old steel lined heater trying to drain the rust out would be useless.
Old 12-16-2012, 11:34 AM   #3
I have a brand new Bradford White gas water heater if that helps. Brand New as in 3 months old. All the pipes leading up to and Away from the heater are copper pipes
Old 12-16-2012, 12:25 PM   #4
Then just hook a hose to the bottom of the tank and drain off some water about every 6 months.
The heater will last longer.
Old 12-17-2012, 01:23 AM   #5
Special User
The plumber wants to sell more water heaters. I flush mine annually, always get lots of crud shooting out. Mostly white chunks of corroded anode rod. It's also a good idea to inspect and if necessary, replace the inexpensive anode rod every 3-6 years. If you do that and flush, your tank could last for decades.
Don't forget to test the T&P valve every time you flush. Just put a bucket under the discharge pipe and pull the little lever a couple times.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Old 12-25-2012, 12:02 AM   #6
The above by Tylernt is excellent advice. It will double the life of the water heater.
Ron S. is offline   Reply With Quote
Old 12-25-2012, 10:42 AM   #7
i have heard that if the heater hasn't been flushed in a while, it shouldn't be flushed. as the valve could leak or break.
any trueth in that ?
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is offline   Reply With Quote
Old 12-25-2012, 11:11 AM   #8
Master Plumber
Javiles's Avatar
Best to start when the unit is new every six months or yearly. will prolong the life and efficiency of the unit, on older units your just looking for problems.
Experience is Knowing what to do next, Skill is knowing how to do it
Javiles is online now   Reply With Quote
Old 12-25-2012, 01:36 PM   #9
Why that urban legend got spun is that once in awhile a piece of sediment gets lodged in the drain valve and you can't turn it completely off.
If you got a garden hose cap in advance you could hurriedly screw that on so you don't end up with all 40 gallons of water out on the floor.
One other issue is if the tank is almost rusted out and the layer of sediment is keeping things together for the time being. Once you flush out and stir up the sediment, the bottom of the tank finally breaks through and springs a leak. (Gas and oil heaters: ) The layer of sediment inside also hastens the rusting out of the tank because it is an insulating layer and the bottom of the tank gets hotter than normal, damaging the glass or porcelain lining.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Old 12-25-2012, 05:49 PM   #10
Household Handyman
The original post was about flushing rust from a gas water heater. The plumber is entitled to his/her opinion. Then we find out that the water heater is only three (3) months old with copper piping. The question of rust here is moot. IMO-electric water heaters will build up sediment in the bottom quicker than a gas unit will. This also depends on the water in your area. Flushing out some water from a water heating unit on some type of schedule is not a bad idea no matter which type unit you have or what the water conditions are. Sediment is not good in water heating units.
Old 12-26-2012, 09:23 PM   #11
i'm still afraid to try it. bad things like to happen to me. and that could be a can of worms.
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 10:55 PM
Gas Water Heater, water not hot enough - Thermostat or Sediment makunag Plumbing 15 08-28-2010 12:00 AM
water heater drip kdange1 Plumbing 5 05-04-2010 04:24 PM
Water connections for new water heater diggerdave Plumbing 16 03-16-2009 11:36 AM
