Flushing A HWH - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-16-2013, 12:59 PM   #1
Rewards Points: 2,038
Flushing a HWH
new topic
Browsing HWH's in a big box store a clerk told me to hook a hose up to the bottom of the HWH, (every 6 mths) then turn the HWH knob off to stop water going in...........then to turn on a hot water faucet in a sink.
He said to run the hose outside and flush out the tank for 3 minutes.
I've never heard of this before but I know we have bad water here. By bad I mean, if any water stands in the bathroom sink it leaves black marks.
My question is: do the plumbers on here recommend this flushing?
Startingover is offline   Reply With Quote
Old 05-16-2013, 01:12 PM   #2
Plumber & Gasfitter
Rewards Points: 77
I recommend doing all the manufacturer suggested maintence as per your HWT manual including flushing the tank and anode inspection/replacement. That said, don't shut off tank water supply and open faucet, just hook up hose and drain a gallon or so with the tank pressurized.
joeplumber85 is offline   Reply With Quote
The Following User Says Thank You to joeplumber85 For This Useful Post:
Startingover (05-16-2013)
Old 05-17-2013, 09:48 AM   #3
Rewards Points: 1,418
The purpose of draining a gallon or two of water from the hot water tank is to flush out particulate matter such as grains of sand or bits of rust that came in from the water main.
If you wait too long, enough of this sediment can accumulate on the bottom that the drain valve doesn't let any water out. Then getting the sediment out gets more complicated.
A lot of sediment on the bottom makes gas water heaters take longer to heat up a tankful of water and can also shorten the life of the tank because the bottom surface gets hotter and may break the glass lining.
The Following User Says Thank You to AllanJ For This Useful Post:
Startingover (05-17-2013)
Toilet flushing issue grand_canyon Plumbing 5 11-28-2011 12:27 PM
Toilet not flushing away contents effectively.... conbutts Plumbing 6 05-24-2011 11:27 AM
Toilet backfill after flushing hohadcr Plumbing 6 12-20-2009 05:01 PM
slow flushing toilet annoyances mcvane Plumbing 12 11-13-2008 04:00 PM
Toilet Flushing ? Piney Plumbing 5 10-20-2007 02:56 PM
