Flushing - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-03-2006, 09:20 AM   #1
Rewards Points: 150
flushing
Can someone out there tell me the probable causes for periodic slow toilet flushing?
What baffles me is 7 out of 10 times it flows like gangbusters, and the other times it swirls and drops slowly and leaves behind waste. Thanks
handifoot is offline   Reply With Quote
Old 08-03-2006, 12:19 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
It most likely has to do with the volume of paper and solids in the flush.
A toilet has a built-in trap, and these "modern" low-flow toilets sometimes just don't flush well.
Mike
Mike Swearingen is offline   Reply With Quote
Old 08-03-2006, 12:42 PM   #3
Can you adjust the water level inside the tank?
If so, then raise the water level slightly.
The water level may be at the point where it is right at the edge of giving the proper flush.
redline is offline   Reply With Quote
Old 08-03-2006, 05:56 PM   #4
Journeyman Plumber
Ron The Plumber's Avatar
Replace the fill vavle in the toilet tank, if the one there now does not work properly, it can make the toilet flush strangley, fushes ok ever 3rd or 4th flush then the other times will seem sluggish.
Ron The Plumber is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Flushing a Steam Heat Furnance helpless handyman HVAC 2 11-06-2006 04:34 PM
flushing receptacals to wall a_theater_god Electrical 3 07-31-2006 04:01 PM
flushing toilet reflux handifoot Plumbing 5 06-30-2006 11:17 AM
Flushing problems Darren Plumbing 1 03-01-2005 10:04 PM
