-   -   flushing (http://www.diychatroom.com/f7/flushing-3307/)
handifoot 08-03-2006 09:20 AM
flushing
Can someone out there tell me the probable causes for periodic slow toilet flushing?
What baffles me is 7 out of 10 times it flows like gangbusters, and the other times it swirls and drops slowly and leaves behind waste. Thankshttp://www.diychatroom.com/images/icons/icon9.gif
Mike Swearingen 08-03-2006 12:19 PM
It most likely has to do with the volume of paper and solids in the flush.
A toilet has a built-in trap, and these "modern" low-flow toilets sometimes just don't flush well.
Mike
redline 08-03-2006 12:42 PM
Can you adjust the water level inside the tank?
If so, then raise the water level slightly.
The water level may be at the point where it is right at the edge of giving the proper flush.
Ron The Plumber 08-03-2006 05:56 PM
Replace the fill vavle in the toilet tank, if the one there now does not work properly, it can make the toilet flush strangley, fushes ok ever 3rd or 4th flush then the other times will seem sluggish.
