Old 01-13-2012, 02:10 PM   #1
flushed
i recently had a plumber install a toilet in my basement. the existing rough-in was 3 inch pipe. a 2x3 fit in flange was installed. the toilet (american standard one piece) that was installed has a really sluggish flush. the supplier claims the toilet should produce a good flush and that they've sold lots with no customer complaints. has the plumber made an error by installing a flange less than 3"
barbwire is offline   Reply With Quote
Old 01-13-2012, 02:23 PM   #2
flushed
My understand is 3" flange in minimum for a toilet. Are you saying it reduces to 2" because it fits inside the 3" plumbing? I haven't heard good things about those fittings.
psilva8 is offline   Reply With Quote
Old 01-13-2012, 02:48 PM   #3
MarginallyQualified
flushed
a 2x3 fit in flange was installed. <-- never used one
the supplier claims... (=yadda, yadda, yadda)
the toilet...has a really sluggish flush. (proof is in the pudding)
has the plumber made an error...?
Unless that toilet REQUIRES this adapter... Then, in my view... yes.
If it is REQUIRED then whoever chose the toilet made the error.
hth
Old 01-13-2012, 07:13 PM   #4
flushed
inside of 3"pipe measures about 2 7/8 to 3" if you insert a flange into that .IT IS TO SMALL FOR A TOILET TO FLUSH PROPERLY....SHOULD HAVE HAD A 3" HUB FLANGE INSTALLED....MAY NEEDED TO CHIP ALITTLE CONCRETE....LAZY LAZY LAZY
Old 01-13-2012, 07:17 PM   #5
flushed
And how is it vented?
ben's plumbing (01-13-2012)
Old 01-13-2012, 11:45 PM   #6
Master Plumber
Javiles's Avatar
flushed
never seen a 3 x 2 closet flange? A first for me… 3 x2 usually 3” pipe 2” deep. Inside hub or outside pipe. Who knows what that plumber did or maybe its just a defective toilet maybe from H/D
Experience is Knowing what to do next, Skill is knowing how to do it
Javiles is offline   Reply With Quote
Old 01-14-2012, 12:18 PM   #7
flushed
maybe the plumber did nothing wrong???????
Old 01-14-2012, 04:44 PM   #8
flushed
called a plumbing supplier. flange is actually 2- 1/2 x 3. they claim that its acceptable for alberta, so i guess the plumber did his job right. maybe toilet is defective.
Old 01-14-2012, 05:37 PM   #9
call me E
TheEplumber's Avatar
flushed
Who supplied the toilet? You or the plumber?
What model is it?
water level in toilet drops when another toilet is flushed target1911 Plumbing 9 09-12-2011 10:45 AM
Just flushed my hot water heater... Jason.W Plumbing 2 07-10-2011 09:43 PM
Shower noisy when toilet flushed joedadog Plumbing 3 04-27-2011 11:56 AM
Flushed water heater but no dirt came out? kwerk Plumbing 7 05-02-2010 06:51 PM
Toilet Leaks When Flushed - How to get at closet bend!! OldHouseNewProblem Plumbing 3 12-11-2008 07:24 AM
