Flush Valve Trouble - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-12-2012, 01:05 PM   #1
Rewards Points: 24
Flush valve trouble
This toilet flush valve fills VERY slowly and when the water reaches the top, it does not shut off.
Is there a way to repair it? If not, does anyone know anything about the make and model of this one so I can replace it?
S_Jeff is offline   Reply With Quote
Old 12-12-2012, 01:13 PM   #2
Hard to say with certainty, but looks like your float (large black balloon) is sitting really low in the water indicating its leaking so it never "floats". Can you confirm?
jmd87 is offline   Reply With Quote
Old 12-12-2012, 01:25 PM   #3
Rewards Points: 24
The picture shows the chamber just after having been flushed. The ball floats as it should, but even when it is floating on the top of the filled tank, the valve does not completely shut off.
If I pull up on the lift arm hard enough, the valve does close, but it takes more force to do this than what is provided by the buoyancy of the float ball.
My non-expert assessment is that the valve itself is corroded and providing too much resistance.
Old 12-12-2012, 02:47 PM   #4
As long as you're certain the extra force is not just from a heavy, water-logged float, then you may be correct. Would also explain the slow fill times.
When you pull up and hold to keep the water off, does it sound like water is leaking/draining as if your flapper isn't making a good seal?
Old 12-12-2012, 03:32 PM   #5
Master Plumber
Javiles's Avatar
Rewards Points: 996
Toss that valve away and replace it (fill valve / ballcock) flush valve is the one in the center that releases the water on flush. also garbage replace it with a standard flush valve ( flapper type ) with the extended overflow, you can add more water to the flush if needed.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 12-12-2012, 03:37 PM   #6
Replace it. They are cheap and lowes carries several different kinds that will fit your application.
southernkilowat is offline   Reply With Quote
Flush Valve Closing too soon - only getting 1/2 flush cody21 Plumbing 16 02-18-2011 08:51 PM
Cant get the valve off (with picture) clof2001 Plumbing 3 05-10-2010 03:04 AM
Leaking pressure relief valve Chris Magee Plumbing 12 08-12-2008 07:48 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
