Flush Valve Closing Too Soon - Only Getting 1/2 Flush - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-09-2010, 05:09 PM   #1
Flush Valve Closing too soon - only getting 1/2 flush
Stumped on this and looking for advice. We have an AMERICAN STANDARD toilet, 2008. It has a "float style" flush valve whereby a tube fills with water. When the chain is lifted to bring up the flapper, the tube drains and the weight barrel in the front of the tube pulls the float mechanism back down thereby stopping water from emptying into the tank.
The problem is that the tube/float drops back down too soon resulting in only 1/2 tank of a flush.
From advice of a local plumbing store, we confirmed that the "hole" in the tube is not clogged. And the chain has enough slack on it.
Any ideas what might be causing this to fall down to soon? The only way I know how to make this work is to hold down the handle long enough to get all the water emptied -- but try telling a 5 year old to do that!
Thanks so much.
cody21 is offline   Reply With Quote
Old 06-09-2010, 05:18 PM   #2
has it just started doing this? there are 3 or 4 diffrent styles of that flush valve for AS water closets, is it possible that someone replaced it with the wrong actuator. they have diffrent degrees of angle. try taping a nickel to the back of the tube for added counter weight. also check that rubber bushing that holds chain in actuator is seated properly
just a guy is offline   Reply With Quote
Old 06-09-2010, 05:40 PM   #3
No - it's been doing this since we bought the house 2 months ago ... (rental) ... the Tenant has been complaining about it and we're just trying to fix it to no avail.
So no idea - but it appears to be the original (2008). We did put a small counterweight to the "tube" (by theupper hole at the top of the tube). I'll check the rubber bushing you mention. Would the water pressure coming from the input water tube possibly be too strong and thereby be pushing it over??? We noticed that there seem to be a pretty decent stream of bubbles/water coming in through that water inlet... Thanks
Old 06-09-2010, 05:54 PM   #4
I guess it could be possible, try deflecting the refill tube as you flush and see if it makes a diffrence. If it does, you could try shutting down supply valve some. (to slow the fill)
Old 06-09-2010, 11:55 PM   #5
can you make hole in the actuator bigger to let more water out faster ??
el cheepo is offline   Reply With Quote
Old 06-10-2010, 09:37 AM   #6
Is the "actuator" the hollow tube that acts as sort of a ballast? How would enlarging the hole help?
Thanks guys.
Old 06-10-2010, 09:02 PM   #7
I=E/R
a7ecorsair's Avatar
In our townhouse that was built in 2005, the Gerber toilets have a water saving "flapper." If the handle is press down and released right away the toilet does a quick flush. The handle has to be held for the "extended" flush. It is all done with the flapper valve. Normally a flapper will float until the tank is empty but on these Gerbers, the flapper doesn't wait for the tank to empty before sealing.
Maybe yours have some type of water saving design.
a7ecorsair is offline   Reply With Quote
Old 06-11-2010, 10:11 AM   #8
Good thought but not the case here. The "actuator" is definietly falling back down too soon. We're going to try taping a small weight at bottom of the hollow actuator and maybe turn down the water flow a hair.
Old 06-11-2010, 05:19 PM   #9
Rewards Points: 150
Some American Standard Toilets have a float on the flush valve designed to keep the flapper open until all the water has drained.
Could you have that type that the float is bad or someone remover it?
braindead is offline   Reply With Quote
Old 06-11-2010, 05:31 PM   #10
Don't think so .... The 'issue' is that the actuator is dropping too soon - and intermittently. (some times it will stay up until the water level in the reservoir is low (like 2 inches from the bottom), other times it drops/closes when only 1/2 of the reservoir empties.) The only sure way to get more water out of the reservoir is to hold the handle for 5 seconds.
Old 06-12-2010, 07:17 AM   #11
you have the option of changing out the flapper of course. I've run into something similar, there was too much slack in the chain. I'd try shortening the chain, try it and watch it a few times. As you know, too short and it will keep running.
LIVING THE DREAM
DUDE! is offline   Reply With Quote
Old 06-12-2010, 08:23 AM   #12
I=E/R
a7ecorsair's Avatar
For the fun of it, I went to the American Standard site
http://www.americanstandard-us.com/bathroom-products/toilets/
Click on the flushing system, there are eight different ways to flush a toilet
Any idea which system is used in your toilet?
Old 06-14-2010, 01:08 PM   #13
wanted to give you all an update on this. We taped a nickle to the bottom of the "actuator" - It's not perfect, but it seemed to help keep the 'actuator' tilted up most of the time to get a full flush. We took a level with us as well. I think the main issue is that the previous owner never LEVELED the install ... the toilet/tank does in fact have a tilt to it from Left to Right (looking at the toilet). So I really think that is what is contributing or causing the 'actuator' to drop too quickly. We could probably loosen the bolts and SHIM the right side of it -- but we're afraid that would (1) break the seal, and/or (2) cause it to wobble, or (3) something worse. So any further repairs/fix would probably best wait until we eventually replace the toilet ..
thanks for all your advice guys.
Old 02-18-2011, 02:47 PM   #14
Same problem with new American Standard toilet
I just replaced my old, constantly-clogging toilet with a new American Standard "Cadet 3" low flush (1.28 gpf) toilet and am seeing the same problem discussed in this thread.
I my case the flush valve has no "actuator" of any kind -- just your typical rubber flapper attached to two ears on either side of the overflow valve and a chain connected to the flush handle.
The chain is adjusted fine (no significant slack and the flush valve isn't leaking).
When I press the flush handle and quickly let go, only about half of the water in the tank flows into the bowl, resulting in a "half" flush. I have to continue holding down the handle for approx. 3-4 seconds to get the tank to fully drain.
The old toilet I just replaced, along with every other toilet I've ever installed, didn't have this problem. The flapper valve has always stayed open "on its own," even after you let go of the handle.
I paid just under $200 for this toilet -- not the world's most expensive, but not exactly a cheapie either. I certainly didn't expect to run into a "design" problem like this.
I guess I'll start by contacting American Standard to hear what they have to say about this issue.
Any other suggestions?
Thanks.
prlaba is offline   Reply With Quote
Old 02-18-2011, 02:50 PM   #15
Originally Posted by prlaba View Post
... snip ... I guess I'll start by contacting American Standard to hear what they have to say about this issue.
Thanks.
Did you verify that it was LEVEL when you bolted it down? Just a thought.
Replacing flush valve on one-peice Kohler Toilet griffin2000 Plumbing 6 01-14-2016 10:43 PM
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
Kohler toilet flush valve yarp1 Plumbing 2 04-01-2010 08:59 AM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
Help with spud washer on toilet flush valve meck23 Plumbing 13 01-21-2008 08:24 AM
