Old 03-31-2006, 09:34 PM   #1
Flush toilet, hear shower drain noise
Sometimes when I flush the toilet on the second floor of my home, the shower drain in the same bathroom makes noise. It sounds like the water is coming up the shower pipe and then draining down. Is it a clog in the vent or the wast line? Thanks..
joedadog is offline   Reply With Quote
Old 04-01-2006, 01:52 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
Sounds like a partial clog in the main drain line.
You can try snaking the main drain line with a heavy-duty plumber's snake down the vent stack pipe on the roof or a clean-out plug, if necessary. Flush it down with a water hose sprayer.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Installing basement shower drain atilla137 Plumbing 5 09-03-2009 12:54 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
Food backing into shower drain Manuel6 Plumbing 5 11-23-2006 09:59 AM
shower drain nomoney Plumbing 4 05-19-2006 10:27 AM
Toilet making Noise DSHMSH Plumbing 1 12-22-2005 05:33 PM
