Fluidmaster 400A - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-18-2013, 11:41 AM   #1
Rewards Points: 130
Fluidmaster 400A
Is there any further adjustment of Fluidmaster 400A? I bought one and its to sensitive. The slightest movement of the bowl (sitting down) will actuate the valve for less than one second.
Also does it occasionally by itself. Real fast and quick.
The hose has been trimmed short so it does not go below the water line.
The water level is low as I have a low flow tank. 1.8 Gallons. The valve is as far down as it can go so the lid will not hit it.
The flapper has not been replaced. But I did remove it, check it good and cleaned it.
I have read all of Fluidmasters instructions and have done everything accept use the the little hose holder. My fill tube has its own little holder located inside the tube.
Any suggestions.
Old 02-18-2013, 05:29 PM   #2
Lightfoot's Avatar
Rewards Points: 272
sorry you haven't received an answer yet.
I have put dozens of the fluidmaster 400's in service and i have never once had that problem--maybe someone here has, but i just don't know what to tell you. All the ones i have seen will not kick on until they drop (and not just a hair).
If it comes on by itself, you may have a flapper leaking slowly. Put some food coloring in the tank and see if your bowl shows color after a while. But that still doesn't explain the short spurt fills.
Hope someone can answer
Flashlight: A cylindrical container used to store dead batteries
Lightfoot is offline   Reply With Quote
The Following User Says Thank You to Lightfoot For This Useful Post:
joecaption (02-18-2013)
Old 02-18-2013, 05:56 PM   #3
Rewards Points: 252
It's possible it could be defective. I can only speak of my similar experience with a new fluidmaster 400 in my toilet. I, like you tried everything, with no positive results. It seemed like it was very sensitive to everything. So I took it back and got another one and it worked fine with no problems.
One quick thing to check - That little tube you mentioned that goes from the fill valve to fill tube, make sure it is not pushed down inside of fill tube. It could siphon water out and give same sympton as a leaky flapper. Use the hose/tube clip that comes with the new fluidmaster 400a even though your fill tube has a place for the little tube.
jmon is offline   Reply With Quote
Old 02-18-2013, 07:03 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,192
John,
I had the same issue. Try turning off the stop, removing the top cap on the Fluidmaster, hold a paper cup over the top and turning on the stop for a second. This will blow out any debris. Replace the cap. If this does not work, replace the Fluidmaster.
That's what happens when an electrician turns plumber
Coastal South Carolina
The Following 2 Users Say Thank You to rjniles For This Useful Post:
J. V. (02-20-2013), jmon (02-18-2013)
Old 02-18-2013, 07:16 PM   #5
Rewards Points: 252
RJ,
That is also a very good point.
Additionally, lightfoot mentioned the food coloring method which is also a good way to see if flapper or fill tube have a problem.
I'm sure JV has tried just about everything we mentioned. Hopefully we can give him a few more ideas to try before he takes it back.
Thanks.
Old 02-18-2013, 09:29 PM   #6
Master Plumber
Javiles's Avatar
Rewards Points: 994
Have the tank fill and then shut the water off to the tank , then mark the water line, check it in a couple hours see if its had any loss, also poor water pressure will cause a similar problems, these valves work on counter pressure to shut them self off.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 02-18-2013, 10:53 PM   #7
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Use the bowl primer tube attachment fluidmaster gave you. It's designed that way for a reason.
Make sure that the float is not touching the side of the tank or near it in any way. If it lodges itself in the off position, and you have the bowl primer line down into the overflow, it may be slowly siphoning, and when you sit and bump the tank, the float is dislodging from the wall of the tank and dropping to an on position.
Just guessing here though.
Journeyman Plumber
Old 02-20-2013, 02:23 PM   #8
Rewards Points: 130
It was at first and then I remembered that the little hose needed to be up higher. Above the water level. I brought it up.
Originally Posted by rjniles View Post
John,
Ain't that the truth. I am cheap and try to fix everything myself.
I was on a roll until this.
My wife has lost all faith in me now.
I will do that right now. Thanks.
I just have to say I am thinking the exact same thing. The little hose (bowl primer tube) has its own holder that I did not use.
It looked funky and my tank has its own holder located inside the fill tube.
I am going to install what came with the damn valve.
Thanks very much.
I will report back.
The Following User Says Thank You to J. V. For This Useful Post:
jmon (02-20-2013)
Old 02-22-2013, 12:20 PM   #9
Rewards Points: 130
Update.
Marked water line and turned off supply.
Installed little hose holder that came with the valve. (note: remove hose holder located inside fill tube first, or get wet).
Checked water two hours later. It was 1" below mark. So I replaced flapper. Seems to be fine now.
One more question.
The flapper does not fall perfectly straight onto the hole. It is a bit to the left, but seems to be covering the hole. Is there a way to adjust a flapper? To make it fall directly over the hole? The fill tube and the flapper holder seem perfectly lined up. But the flapper wants to fall slightly off center.
Old 02-22-2013, 09:15 PM   #10
Rewards Points: 252
I don't really know what the inside of your toilet looks like. Can you take a pic of it looking straight down?
Couple of quick things to try;
Take a little slack out of the chain and move anchor on the arm to a point closer to over the flapper and see if that helps.
Try to bend the rod if it's metal, careful not to break it, so that the flapper gets lifted straight up and down, see if that helps.
Make sure flapper is positioned on those plastic hooks on filler tube properly.
As long as the water is staying in the tank and not leaking into the bowl, It's really no biggy. If it's leaking into the bowl then, yea, I say fix it. Because you are literally throwing money down the drain with the loss of water.
Let us know how it worked out for you. Thanks.
Old 02-23-2013, 02:07 PM   #11
Rewards Points: 130
Thanks jmon.
It seems to be fine. I have not heard a peep from it since I replaced the flapper.
I noticed the original flapper sat off center also.
Hopefully its fixed now.
Thanks for all the help guys.
Old 02-23-2013, 05:08 PM   #12
Rewards Points: 252
your welcome JV, glad it worked out for you.
Fluidmaster toilet leak juzdownunder Plumbing 9 07-15-2012 06:07 PM
400A underground Main service intelspec Electrical 7 02-22-2012 01:22 AM
Switching to a fluidmaster fill valve inside an old briggs tank. pinecone12 Plumbing 8 01-20-2012 02:30 PM
Fluidmaster 400 no removable cap? sterv Plumbing 13 01-11-2012 10:43 PM
400A service upgrade and transfer switches gregrebholz Electrical 1 01-05-2012 05:31 PM
