Flow Rate At Reducer - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-16-2010, 04:59 PM   #1
Flow rate at reducer
I have a Sunmaxx Solar Water tank with G1 male fittings for hot out, cold in. The house piping to existing tank is 1 1/4". Leaving tank it is 1".
A (G1 x 3/4 NPT) is included with Solar tank. If I use the included fitting, and immediately expand from 3/4 back to 1", what kind of flow pressure effects will I experience.
SIDINC is offline   Reply With Quote
Old 09-16-2010, 08:07 PM   #2
Not 100% sure about solar, but a standard tank is not considered a fixture, does not have fixture units, and does not significantly reduce flow/pressure. I'm thinking that unless you're using lots and lots of hot h20 somewhere, or the lines run a really long way to get to where they go, you probably won't notice the difference. Most faucets run just a couple gallons per minute, as do most showerheads. If you're really worried about it, and its still an option, then plumb the water lines to the fixtures larger (3/4" to each fixture branch, 1/2" just up to the fixture)
the_man is offline   Reply With Quote
Old 09-17-2010, 09:05 AM   #3
Your pressure drop will be minimal since the length of the 3/4" fitting is very short. Only if you are running long distances at 3/4" and bump back up to 1" will you see more of a pressure drop depending on the flow rate.
The Engineer is offline   Reply With Quote
Moving HVAC ducts/registers & reverse flow ?'s cbrc5eric HVAC 3 06-09-2010 05:05 AM
Reducer scribed to fit door jamb? Please Help!! joemontana16 Flooring 1 03-14-2010 10:47 AM
Flow switch use in Hydronic Heating System sarlaud HVAC 14 02-02-2010 07:03 AM
Hot water faucet pipe thumps then flow slows down. DIY-Indy Plumbing 9 07-15-2009 11:09 PM
very low shower head flow rickard681 Plumbing 7 10-08-2008 06:43 AM
