#1 |
Flooring over basement floor drain
so the previous owners did the basement, we had to rip it out and are in the process of redoing it (never guess why?... lets just say plumb to them ment walls at 80 degree angles...) anyways.... pulled up carpet and found a drain under it... now I knew there was a drain in the furnace room which is uncovered, and is constantly filled with water by the condensate drain on the furnace, humidifier drain and AC condensate year round.... this one is on the complete opposite side of the house (50 ft away).. our plans where to dricore the basement but unsure if i should just go over the drain or not? part of the point of dricore is to create space for water to run under if it would get water under it, therefore you need a drain somewhere... but what happens if the trap dries up? or should it dry up in a basement floor? if its covered by dricore it wont be easy to get to to fill up with water, ontop of that there will be carpet also
#2 | |
Tileguy
Flooring over basement floor drainQuote:
![]() Does the floor slope to the drain? |
#3 | |
yes it is 1/2" lower then the rest of the floor around it and it starts a slope from 10 ft out in all directions I just dont get how the previous owners didn't have a problem, it never had a smell or anything there and the trap was dry |
#4 | |
Tileguy
![]() What does DriCor say about using their product over a sloping or dished floor? The floor drain may be clogged and in this case that's a good thing maybe. Products available to cover that type of floor is limited.
#5 |
I would either install a trap primer or cap that drain off.
If the main sewer backs up it may find its way to the floor drain and that would be a nasty clean up job. |
#6 |
Tileguy
This is headed in a bad direction and one I no longer comprehend so for that reason...
I'm outta here.
#7 | |
no mater what there is a sub floor going down, I already made that decision, weither its dricore, subflor or delta PL and OSB/Ply over it, somethings going down now I'm just stuck on getting information and ideas on what to do about the one drain that will be covered up, the other drain never will be as its in a room where there will never be a sub floor (furnace room) |
#8 | |
Doing it myself
Journeyman Plumber |
#9 | |
| Display Modes | |
| Best flooring option for basement flooring | bristo_99 | Flooring | 2 | 11-09-2011 10:59 PM |
| Basement flooring options over lenolium? | ADaniLion | Flooring | 3 | 05-25-2011 04:59 PM |
| basement flooring | Master Brian | Remodeling | 4 | 05-20-2009 10:50 PM |
| Basement Flooring ... | njchan | Flooring | 3 | 03-19-2008 07:02 PM |
| Basement flooring choices | Brik | Building & Construction | 23 | 01-27-2007 03:38 PM |
