Floor Sink?/utility Sink Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-19-2009, 11:59 PM   #1
Angry
floor sink?/utility sink drain
I am putting a floor sink? in my laundry area in lieu of a laundry tub. I just had all the cast iron all the way to the main replaced with ABS. The plumber located the 3" drain and trap where I wanted it and stubbed up a 3" pipe so I can cut it down when I figure out the floor level. Three of the walls will be a 6" reinforced concrete block wall with the "curb" being 4" block, all tied together at the corners and elswhere with rebar and probably 4 courses high. Since I need a footer for the walls I wanted to just pour a monolithic slab with the perimeter level for the block and the center being sloped toward the drain. I was going to use a roll on rubber membrane on the floor and up the walls. My question is, does the floor and wall have to be independent of each other or do I have to form the footer, pour it then pour the center(sink floor) separately? also if I'm pouring concrete anyway do I still need a sloped mortar bed or is a steel troweled finish suitable? This is driving me crazy, I'm ready to cut off the trap, cap the pipe, pour over all of it and purchase a regular laundry tub!!
Sorry for the mini novel and thanks to anyone who can help.
torno is offline   Reply With Quote
Old 01-20-2009, 09:16 AM   #2
Rewards Points: 1,910
Have you considered one of these:
http://www.centralrestaurant.com/24-...c113p4962.html
You wouldn't need a footer or block walls. If you want taller walls on 3 sides you could frame short walls, place tile backer board around them, membrane or redguard and tile like a miniature shower.
I'm not familiar enough with building your own basin with concrete and mortar but I would think you'd follow the same process as for a traditional style built in place shower. If I recall you'll end up building a sloped base , cover it with membrane and then top it with another mortar layer but I can't help with the details.
pedestal sink drain stopper not working gernith Plumbing 7 04-18-2008 09:17 PM
How to drain a utility sink that is in basement? Mikey Palmice Plumbing 40 01-28-2008 09:11 PM
Sink doesn't drain into Septic but somewhere else? 40s house? Where? twilightcall Plumbing 11 01-18-2008 08:36 AM
Drain placement for sink simonb Plumbing 3 09-08-2007 01:08 PM
installing vessel sink drain?! (HELP!) tara Plumbing 2 11-10-2006 12:17 AM
