Floor Drain For Water Heater Drip Pan - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-10-2012, 12:00 PM   #1
Rewards Points: 49
floor drain for water heater drip pan
My inspector told me to install a floor drain for the water heater drip pan and water heater relief valve. This is right above the crawlspace.
does it need to have a P-trap? or is there something else
to use... how does that not dry out?
im in park ridge, ill
thx for input
john_bry is offline   Reply With Quote
Old 12-10-2012, 12:05 PM   #2
Rewards Points: 13,260
No trap needed, But I would make sure it runs to an outside wall not just dump under the house.
Old 12-10-2012, 12:22 PM   #3
Roofmaster
Rewards Points: 2,172
Trap
Hi John,
The purpose of a trap is so that you do net get sewer gas into your home. The water trap prevents this. There is no sewer gas in your setup. It would dry out pretty fast anyway even if you had one to halt air or insect infiltration.
Old 12-10-2012, 12:43 PM   #4
Rewards Points: 49
thx for input!
So it doesnt make sense to connect to the sewer because the trap would dry out, bugs, etc.
Just pull the line to the outside?
Old 12-10-2012, 12:57 PM   #5
Rewards Points: 1,440
The soil underneath the house may be wet 24/7. The reason why you run the water heater tray drain out away from the house (and perhaps into a sewer) is that the floor drain connected to nothing but the ground below might not be able to absorb a larger flow from the tray fast enough and would then overflow onto the floor.
AllanJ is online now   Reply With Quote
Old 12-10-2012, 01:06 PM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 440
In my area we achieve this 2 ways- first is a floor drain connected to the sanitary system. It requires a ptrap. Since it is a seldom used trap it should also have a trap primer. These give a "squirt" of water to the trap periodically to keep it from drying out.
The other method is to pipe both lines directly to the exterior- if allowed.
I prefer the floor drain because it will also help you if you have to clean up a lot of water!
Sent from my iPhone using DIY Forum
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
Drip edge under felt Jeoroc24 Roofing/Siding 1 09-07-2011 11:40 PM
Poor Hot Water Pressure After HW Heater Flush linuxrunner Plumbing 4 04-07-2011 08:24 PM
Water Heater blowing out Power to Entire House tbigley Electrical 5 03-02-2011 03:54 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 11:02 AM
