Floor Drain Venting And Sizing.. - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-26-2011, 11:07 PM   #1
floor drain venting and sizing..
Need help trying to figure out how to size floor drains size of opening,trap and drainage pipe....cant figure out online formula....floor drains will be installed in a public restroom....also do floor drains need to be vented if they are within a certain feet from a main building drain,,,,, please help.....thank you all.......
dansn2it2 is offline   Reply With Quote
Old 03-27-2011, 12:43 AM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 676
Depends on what code your town uses. For me its 2" drain and trap, and it must be vented. Drainage fixtures=2. 11/2" vent.
Old 03-27-2011, 07:51 AM   #3
Plumb or Die!
In Canada, a floor drain need not be vented if it is minimun 3" in size, and the trap arm (pipe from the main drain to the trap) is a minimum of 16" long, maximum 12 feet with 1/4" per foot grade on it.
plumber666 is offline   Reply With Quote
Venting ponch37300 Plumbing 41 02-23-2013 10:37 PM
venting help lennox slp98 70,000 propane dgdrx HVAC 8 03-01-2011 05:26 PM
vent sizing kibblesret Plumbing 0 01-23-2011 11:29 AM
Attic venting, half heated/half unheated Treeplanter Roofing/Siding 3 10-28-2010 09:12 PM
Nat. Gas B-Vent sizing hiondetails HVAC 2 09-14-2008 06:16 AM
