Old 08-10-2007, 01:13 PM   #1
floor drain with a stopper
here is my project:
i am building a custom-designed wash tub in my basement which will look much like a tub used in many janitorial stations. it will be separated by a one-foot wall and inside i want it to look like a tile shower, i.e. have a FLAT drain (a circular one with a grid).
however, what i also want but have never seen with floor drains is the ability to stop them. the tub will also have a spout, much like a sink one.
a shower setup will not work because the drain is not flat. a sink setup will not work for the same reason. does anyone know what avails to correspond to this design ? think of a floor/shower drain which has a stopper.
thanks very much,
- a
Old 08-13-2007, 10:04 AM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Not that I'm aware of.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 08-13-2007, 01:05 PM   #3
Talking
Old 08-13-2007, 01:12 PM   #4
Agent 000
SecretSquirrel's Avatar
If you get desperate you can cut a circular piece of thin rubber large enough to cover the drain and the static pressure of the water will hold it down while allowing the level to rise to your liking. Or you can pay 20 buck$ for something like this laundry sink stopper.
Or look at this; http://www.insidestore.com/jump.jsp?...CT&itemID=2854
SecretSquirrel is offline   Reply With Quote
More On This Topic
Once you get all of your plumbing in. Now on this sink, the drain is set forward from the drains coming out of the sink because of the remodel. This inlet right here is going to go to the dishwasher on this side of the sink. We had to use a flexible hose... Read More »
People are now living to be in their upper eighties, and beyond. This rise in the senior population is bringing the need for safe, accessible bathrooms to the foreground. No one wants to think their elder parents are facing hygiene hardships. Many... Read More »
Faucets should accentuate the overall appearance of your bathroom. You can choose from a large selection available at hardware stores, home centers, bath remodeling showrooms and plumbing wholesalers. You can also shop online. Whether you are replacing... Read More »
We got our drainage for the, we're back over to the first tub we have our drainage up here ready to install it in the tub. If you notice I've reinforced the plastic flat with some cans and we're going to take them and put them over the drainage hole. The... Read More »
We are doing a kitchen remodel, and we’re installing the sink. We have replaced one of the supply lines, we have the sink in, and the supply line is connected to the outlet valves. Now we’re going to install a dishwasher drain. You put it on... Read More »
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
