Floor Drain / Sink Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-30-2013, 07:44 AM   #16
Ghostmaker obviuosly is correct with regards to the issue first off a commercial install is not to be confused with a residential install and no residential install is to be indirectly discharged. I think your confusing a floor sink with a floor drain which a floor sink provides an air gap for indirect waste to prevent contamination of the indirect waste line. He did cite proper code its right there in black and white and irrefutable, if you chose to do it another way than that of course is your decision but it would not be proper code.
Peppe1019 is offline   Reply With Quote
Old 08-30-2013, 07:09 PM   #17
Rewards Points: 1,954
Originally Posted by Anti-wingnut View Post
I've built about twenty restaurants and I'm 53. How about sweetie?
Good now you should just get a grip on your reading skills.
And your a young punk!!!!
simple question regarding kitchen sink drain donkeyk Plumbing 6 05-31-2012 09:32 AM
Double Bowl Kitchen Sink Drainage Problem PeteW Plumbing 16 09-05-2011 09:41 AM
Finishing basement....sink won't drain jerrydlish Plumbing 1 08-19-2009 08:36 PM
Sink won't drain kchopper Plumbing 5 06-07-2009 09:42 PM
Drain placement for sink simonb Plumbing 3 09-08-2007 01:08 PM
