WHICH Floor Drain For Second Floor Laundry Room?? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-07-2012, 09:17 PM   #1
WHICH floor drain for second floor laundry room??
I'm hoping I will never get a flood in my new laundry room and will be using a new washer and the most burst-proof hoses I can find, but... just in case, I'm tiling and epoxy grouting the whole room and plan to put a drain in the floor.
But all I see are shower drains, either designed for thin shower bases (my plywood is 1 1/2" thick, so can't tighten the nut on it to hold it securely) or else designed for a shower pan with liner.
I just want a 2" solvent weld drain that can be firmly attached to the floor - square would be nice tile-wise.
Any ideas?
Thanks!
thatbobguy is offline   Reply With Quote
Old 10-07-2012, 09:23 PM   #2
unless you have a curb along the doorway the water is gonna run down the hallway anyway. try a pan under the washer with a kitchen sink basket strainer in the bottom hooked up with 1-1/2 inch pipe piped to your overhang.
Old 10-07-2012, 09:27 PM   #3
Rewards Points: 13,458
A pan and one of these.
http://www.amazon.com/Watts-EDP00046.../dp/B00093DU5A
Old 10-08-2012, 01:16 AM   #4
I've planned a curb already, and I have 2" abs mapped out going from the tentative drain location to the basement stationary tub.
Looked into washer pans already - they only catch washer-specific leaks, and where they'd drain is the one spot I can't get to from below.
Old 10-08-2012, 04:52 AM   #5
DIY staff
Rewards Points: 7,174
Floor drains in second floor laundys are required by code in this area---
A standard floor drain with an adjustable cover works well---have you gone to a plumbing supply store yet?
Painting the backer with Hydroban or Aqua Defense---and using that to seal the drain to the backer--will give you a water proof floor under the tile---
Old 10-10-2012, 01:00 AM   #6
"Adjustable" was the key word I was looking for - adding it to my search criteria brought up this beauty:
http://www.siouxchief.com/Drainage/C...o-Drain2.EF1IF
Old 10-10-2012, 09:37 AM   #7
Plumber
TheEplumber's Avatar
Rewards Points: 564
I didn't check the pricing on that but this one will do it too and it doesn't have that word "commercial" on it
http://www.siouxchief.com/Drainage/R...an-Drain.R3BWQ
Insulating a cold/well room? Lynch Building & Construction 23 07-25-2014 02:49 PM
Need a foundation in my laundry room sweetfarm Building & Construction 14 09-06-2012 09:49 PM
Vapor Barrier on elevated 4 season room Indyc0lt Insulation 3 09-15-2011 01:41 PM
Sizing Window AC For Open Room appleye1 HVAC 17 07-29-2010 10:00 AM
What Makes A Room A Bedroom? HowToGuy Remodeling 11 02-26-2010 02:44 PM
