-   -   WHICH floor drain for second floor laundry room?? (http://www.diychatroom.com/f7/floor-drain-second-floor-laundry-room-159339/)
thatbobguy 10-07-2012 10:17 PM
I'm hoping I will never get a flood in my new laundry room and will be using a new washer and the most burst-proof hoses I can find, but... just in case, I'm tiling and epoxy grouting the whole room and plan to put a drain in the floor.
But all I see are shower drains, either designed for thin shower bases (my plywood is 1 1/2" thick, so can't tighten the nut on it to hold it securely) or else designed for a shower pan with liner.
I just want a 2" solvent weld drain that can be firmly attached to the floor - square would be nice tile-wise.
Any ideas?
Thanks!
DannyT 10-07-2012 10:23 PM
unless you have a curb along the doorway the water is gonna run down the hallway anyway. try a pan under the washer with a kitchen sink basket strainer in the bottom hooked up with 1-1/2 inch pipe piped to your overhang.
joecaption 10-07-2012 10:27 PM
A pan and one of these.
http://www.amazon.com/Watts-EDP00046.../dp/B00093DU5A
thatbobguy 10-08-2012 02:16 AM
I've planned a curb already, and I have 2" abs mapped out going from the tentative drain location to the basement stationary tub.
Looked into washer pans already - they only catch washer-specific leaks, and where they'd drain is the one spot I can't get to from below.
oh'mike 10-08-2012 05:52 AM
Floor drains in second floor laundys are required by code in this area---
A standard floor drain with an adjustable cover works well---have you gone to a plumbing supply store yet?
Painting the backer with Hydroban or Aqua Defense---and using that to seal the drain to the backer--will give you a water proof floor under the tile---
thatbobguy 10-10-2012 02:00 AM
"Adjustable" was the key word I was looking for - adding it to my search criteria brought up this beauty:
http://www.siouxchief.com/Drainage/C...o-Drain2.EF1IF
TheEplumber 10-10-2012 10:37 AM
I didn't check the pricing on that but this one will do it too and it doesn't have that word "commercial" on it
http://www.siouxchief.com/Drainage/R...an-Drain.R3BWQ
