Floor Drain And S-Trap Q's - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-16-2012, 08:09 AM   #1
Floor drain and S-Trap q's
This is related to a replacement basement sink
What is the best way to attach an S-Trap to a floor drain that is not coming out the floor straight?
The floor drain is iron pipe, I removed the old metal cleanout and chrome/brass s-trap but left the metal 1-1/2" nipple on the iron "hub". (Looks like a reducer with female threads was leaded into the hub with a 1-1/2" nipple attached)
Here is what I did: Attached a 1-1/2" threaded male adapter to the nipple(female thread/coupling). Then a 1-1/2" T fitting with a male adapter/cleanout plug and a 1-1/2" compression type fitting on the top.
Then installed a S-Trap, seen here:http://www.lowes.com/pd_172446-143-7...rap&facetInfo= .
The s-trap leaked at the middle s-trap joint(the slip joint where the 2 U shapes meet), so I dissasembled it, added joint compound to the middle joint and made that up first, then tightened the other joints.
This stopped the leak but how long is it going to last? The drain being slightly bent coming out of the floor is an issue, IMO tightening the pipe that went to the drain first was not allowing the middle joint to seat properly.
Any thoughts on this or better methods?
homeplumb is offline   Reply With Quote
Old 10-16-2012, 08:21 AM   #2
Rewards Points: 14,312
Well since an S trap is not even legal anymore you off to a bad start.
Got any pictures of what your trying to do?r
Old 10-16-2012, 08:32 AM   #3
Why illegal?
I have no pics at the moment, its in an old house and basically replacing the the old with new.
Old 10-16-2012, 08:38 AM   #4
Is there even a vent for this sink?
Without a picture you get lots of questions and fewer ansewers.
It has to do with the traps getting sucked dry when using a S trap.
Old 10-16-2012, 08:53 AM   #5
Ill take some pics and post them today
As far as venting, I would say no...the house is probably early 1940's and the original setup was basically exactly as what I replaced.
I thought the same thing myself, no vent piping seemed strange, so i just replaced the old with new.
Old 10-16-2012, 09:06 AM   #6
Rewards Points: 1,014
If we are talking about the replacement of an existing S-trap, in an assembly that dates to the '40's, then legality should not be an issue what-so-ever
Anti-wingnut is offline   Reply With Quote
Furnace condensate drain/trap issue SteveC HVAC 33 12-27-2012 11:46 AM
PVC trap adapter on galvanized trap? dougan Plumbing 2 10-05-2012 06:16 AM
Would this be a 'P' trap or an illegal 'S' trap? klondiker Plumbing 7 04-06-2012 10:18 PM
Trane XR90 - Condensate Drane Trap JDWorks HVAC 16 02-07-2012 07:59 PM
kitchen wall drain outlet higher than trap arm Druidia Plumbing 24 10-13-2011 12:39 PM
