Floor Drain Retrofit For Slab On Grade - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-31-2009, 06:01 PM   #1
D-I-Yer
Floor Drain retrofit for Slab on Grade
I have removed an old washing machine stand pipe/drain that is about 3 inches from the wall in a slab on grade (main floor of the house). It has a trap in the bottom. It is 2 inch cast iron with no flange visible and is flush with the floor.
Can this be easily converted to a floor drain? The floor will be ceramic tiled as a finish. There is no slope, but I was hoping to use it as a hedge against future washing machine problems.
Douger_F is offline   Reply With Quote
Old 04-01-2009, 08:06 PM   #2
skyman's Avatar
Typically, floor drains are 3" and have slope, but 2" will work fine. I assume it's vented correctly since it was a washer drain. If you're putting Tile down, you have about 1/2" to put a strainer on if you can find one that's 2". Worth a shot.
skyman is offline   Reply With Quote
Old 04-01-2009, 09:08 PM   #3
D-I-Yer
Within 3 feet there is a 3 inch vent pipe on the proper side of the trap, so venting is not an issue.
Old 04-02-2009, 11:07 AM   #4
skyman's Avatar
3 feet is plenty of distance to the vent. Also, I meant to tell you earlier, you're not going to find a strainer (I can't think of the specific name for it) to block large objects from going into the drain at a hardware retail store like Ace, Home Depot, or Lowe's. You're going to have to call around a specialty store like Winnelson, Master's Supply, a wholesale company like that to find one that will fit 2". Good luck brother. I have one more piece of advice for you, never pet a dog that's on fire.
How do you handle grade changes? kentuckytwostep Flooring 12 01-26-2009 12:52 PM
Outdoor outlets jamiedolan Electrical 1 01-17-2009 11:15 AM
Below grade fireplace venting BillL HVAC 7 01-15-2008 07:20 PM
What Grade Lumber? snmhanson Building & Construction 3 10-22-2007 01:29 PM
What is apartment grade carpet? darsunt Flooring 4 06-05-2007 05:50 AM
