Floor Drain Or NO Floor Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-20-2009, 06:19 PM   #1
Floor drain or NO floor drain
We are going to be having a concrete slab poured. We currently are having some plumbing work done and the plumber asked me if I really needed a floor drain in the utility room. There will be the hot water heater in the utility room. It got me to thinking about what someone else said to me about probably never needing a drain and leads me to the question; if it was your house would you even install a floor drain to begin with ?
Mudball is offline   Reply With Quote
Old 12-20-2009, 06:34 PM   #2
Rewards Points: 1,448
Normally a floor drain is installed when you expect to hose down the floor a lot, for example in a restaurant kitchen or a commercial bathroom.
Normally a floor drain is not installed just to cover the situation when a water heater in the room springs a leak.
Old 12-21-2009, 06:20 AM   #3
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
I'd definitely have a floor drain near the water heater. Even if the water heater never leaks, at some point you're going to have to replace it. Where are you going to drain all that water? Or lets say the water heater does leak. Where is all that water going to go? You could use a shop vac to get it all up, but do you really want to? I'd have the floor drain installed along with a trap primer to keep the trap wet.
JDC is offline   Reply With Quote
Old 12-21-2009, 06:28 AM   #4
Thanks for the help. I agree with both comments. Im leaning toward putting it in since its new construction and the cost wouldnt be as high.
Old 12-21-2009, 10:12 AM   #5
If you decide to have the drain installed, make sure you add water to it once a month. The water in an unused trap will evaporate and allow sewer gas to enter the house. Be aware that the floor will need to be pitched towards the drain. This may cause an uneven feeling while walking in a small room.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 12-21-2009, 01:14 PM   #6
Newbie Bill
Rewards Points: 520
Wouldn't a floor drain be necessary for the condensate for air conditioning and the high efficiency furnaces?
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is online now   Reply With Quote
Old 12-21-2009, 02:08 PM   #7
drtbk4ever, it would be a nice addition, IF the furnace and AC are in the room. From my point of view, it is just something to catch dirt and other things dropped onto the floor. This is where it becomes a choice for the home owner.
Old 12-21-2009, 02:38 PM   #8
If I was going to have a lot of tile floors then I'd want a floor drain to make it easier to empty the mop bucket.
If I still made beer I'd want a floor drain (because there can be a lot of waste water).
If you put a handicap accessible shower in your utility room then you'd automatically have a floor drain.
pyper is offline   Reply With Quote
Old 12-21-2009, 02:47 PM   #9
Newbie Bill
Rewards Points: 520
Good point.
Bill
Old 12-21-2009, 06:38 PM   #10
All great advice. Thanks
