Old 06-18-2010, 12:58 PM   #1
floor drain
hello, i have a floor drain in the basement that goes to clay pipes that are not attached to the sanitary drain,they appear to go to the weeping tiles on the side of the house. i think they are supposed to drain basement water in case of a flood, they seem to be clogged with mud and roots, my question is if i elliminate that clay pipe, can i just put the floor drain into the 4"sewage line or is that not allowed? am i supposed to use a sump pit instead? i am located in toronto ontario thanks
christoff is offline   Reply With Quote
Old 06-18-2010, 01:20 PM   #2
47_47's Avatar
floor drain
I do not know what is allowed Toronto, but around here you cannot connect the floor drains, downspouts.. to your sewer lines. This is to reduce the amount of water that needs to be treated.
What we've got here is... failure to communicate. Some men you just can't reach. So you get what we had here last week, which is the way he wants it... well, he gets it.
47_47 is offline   Reply With Quote
Old 06-18-2010, 02:28 PM   #3
Handyman
floor drain
Same thing goes for Toronto.
canadaclub is offline   Reply With Quote
Old 06-18-2010, 04:43 PM   #4
floor drain
i just did some more concrete breaking, and there is another 4" clay y connection on the sewer drain that is hooked into the floor drain, so the floor drain has 2 outlets 1 seems to go to the weeping tiles or visa versa, and the other to the sewer. i guess i can block off the weeper side and just use the floor drain as it was installed 58 years ago, am i correct?
Old 06-18-2010, 07:46 PM   #5
Civil Engineer
floor drain
Are you asking a legal question or a practical question? Previous posts indicate it is illegal to connect a floor drain to the sanitary sewer in Toronto. Whether you can legally keep an existing connection is a legal matter that only an attorney can address. As a practical matter, if you maintain the connection, your system will function by directing drainage into the sanitary system.
Old 06-18-2010, 07:54 PM   #6
floor drain
hi daniel, i have a permit in place and i would just like to know if i can keep the existing setup to pass the permit inspection ie. would it be considered grandfather claused or not.
Old 06-18-2010, 08:45 PM   #7
Xtreme DIY'r
floor drain
By closing up one side you are essentially changing the setup
IMO then it would not be grandfathered
Old 06-18-2010, 10:14 PM   #8
floor drain
i suppose you are correct, i will contact the inspector to see the best way to handle the situation.thanks
Old 06-18-2010, 10:25 PM   #9
Xtreme DIY'r
floor drain
Here it is not grandfathered in any way
Once discovered it must be fixed
In fact if they find you pumping/draining rainwater into the sewage system you can be fined up to $1500
They had a huge problem with the sewage treatment plant being unable to handle the load during rainstorms
They have run "amnesty" programs to get people to come forward to change their drains
