Old 08-26-2011, 09:07 PM   #1
Floor drain
Have a floor drain that is a 3 or 4 inch clay pipe in a 1950's home. It backed up and flooded the basement after heavy snow melting. First time in 11 years of my owning the house. It appears to be hooked to a storm drain since there was no sewage issue. Any ideas on what can be done without ripping the floor apart? Can this be plugged with cement or is that against code in CT? I have no need for the drain and just don't want another backup. The pipe does not appear to be perfectly round (or have threads since it is clay) so is there any kind of plug that would work?
Idodiy is offline   Reply With Quote
Old 08-26-2011, 10:01 PM   #2
Floor drain
It is part of your storm system. there is an obstruction somewhere in your line. you need to have the line cabled.
plumberinlaw is offline   Reply With Quote
Old 08-27-2011, 12:26 AM   #3
Doing it myself
Alan's Avatar
Floor drain
There's a product out there called flood guard that goes inside the pipe and has a small float that rises and seals off the passageway in case of a backup.
I'm not sure if they make them that large, but it would be worth looking into.
Journeyman Plumber
Old 08-27-2011, 12:37 AM   #4
Floor drain
if you don't intend on using the drain, you can install a expandable rubber plug either 3" or 4" whatever the size. it is like a soft plug in a engine block. you then won't have to worry about anything backing up but remember no drain either.
good luck,
frank........................sewer expert.
handyman8494 is offline   Reply With Quote
Old 08-27-2011, 09:02 PM   #5
Floor drain
when the water table rises with a heavy rain or thaw if the water can't make out your storm sewer it will show up as a backed up storm drain. If the floor drain is capped the water will come thru the walls.
Old 08-28-2011, 12:56 AM   #6
Floor drain
actually, it will follow the path of least resistance.
