FloodStop With A Water Arrester - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-18-2008, 08:06 PM   #1
FloodStop with a water arrester
Can someone tell me if its ok to install a FloodStop valve on a Laundry min-arrester? Both units would be suspended outside of the wall.
Thanks,
Ron
Ronswartz@mac.com is offline   Reply With Quote
Old 09-19-2008, 06:41 PM   #2
Registered User
Termite's Avatar
I don't see any reason you couldn't install the hammer arrestor first, and then the flood stop valves. My only concern would be that they might need some added support, or some sort of strain relief at the supply hoses.
Water softener leak - how do I set it to bypass? Cylanth Plumbing 4 07-21-2010 09:24 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
Low Water Pressure Eagle2 Plumbing 5 05-28-2008 10:29 PM
Help! Water Problem no one can solve! Goonky Plumbing 4 12-24-2007 09:03 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
