Flood Safe Washing Machine Hoses - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-24-2009, 10:19 AM   #1
Flood safe washing machine hoses
I just purchased a new washing machine and installed Floodsafe hoses,the washing machine did not run through its cycle,the supply house sent out another washer,same thing,they then sent a third washer,same problem.After eliminating electrical problems I then started to eliminate plumbing problems, YEP it was the Floodsafe hoses causing the problems,so beware of using Floodsafe hoses on washing machines even if it states on the package they are for washing machines.
I am now wearing clean cloths finally
ielliott is offline   Reply With Quote
Old 12-24-2009, 12:25 PM   #2
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 132
If you put the hose on the tap of your wash tub, did water come out? Almost sounds as if they had a blockage of some sort.
Old 12-24-2009, 04:10 PM   #3
Rewards Points: 183
Or they were put on backwards.
paul100 is offline   Reply With Quote
Old 12-24-2009, 06:32 PM   #4
The action of suddenly calling for water can cause the floodsafes to shut off
They then need to be reset
The floodsafe hoses also had a problem with the connections
They would snap right off - causing a flood
Old 12-25-2009, 12:56 AM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,228
Appliance repairman told me not to use with my new HE washer. The rapid opening of the solenoid valve looks like a line break to the flood-safe and it cuts the water off. Not every time but it will occasionally.
how to fix washing machine front spring rvegab00 Appliances 2 04-11-2012 03:30 AM
FloodSafe Washing Machine Hoses IdahoBob Plumbing 13 10-29-2011 04:23 PM
Tapping water line and drain from sink for washing machine? RyanD Plumbing 2 06-27-2009 08:25 PM
Hooking up a washing machine?? teachtech Plumbing 1 03-11-2008 11:17 AM
Hotpoint Washing Machine issue pjpjpjpj Appliances 3 03-07-2008 12:26 PM
