Flood Proof Valves???? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-07-2010, 06:55 AM   #1
Flood proof Valves????
Does anyone have a recommended check valve for flood proofing, water heaters and softeners and laundry appliances. I have a friend who's all in one water softener resin tank burst last week and I have the same unit
Chemist1961 is offline   Reply With Quote
Old 02-07-2010, 07:15 AM   #2
Not aware of any mechanical check valve that will work, since faucets are opened full all the time, how would it know which is a broken pipe and which is normal. There are floor water sensors conected to a valve that close the valve when detecting water on the floor.
Old 02-07-2010, 08:57 AM   #3
Just do NOT get a "Floodsafe" connection - they break
Old 02-07-2010, 09:26 AM   #4
Doing it myself
Alan's Avatar
Rewards Points: 2,086
I always wondered how those worked. Interesting.
Journeyman Plumber
Old 02-07-2010, 09:36 AM   #5
35 YEAR MASTER PLUMBER
MACPLUMB's Avatar
Exclamation
Stop flood water in house ! !
THIS IS WHAT YOU ARE LOOKING FOR USE THE ONES FOR THE WATER
HEATER IT HAS A SENSOR THAT LAYS ON THE FLOOR AND IF IT GET A
EYE DROPPER OF WATER IT SHUTS OFF WATER AND SOUNDS A ALARM
www.onsiteproducts.com/
JERRYMAC@UTAHWEB.COM
35 YR. MASTER PLUMBER WITH PH.D IN WATER HEATERLOGY, MASTERS DEGREE IN DRAINLOGY,
PLUMB ANY PIPE, SNAKE ANY DRAIN, MAKE COLD WATER BOIL ON A FREEZING DAY
MACPLUMB is offline   Reply With Quote
Tags
flood , hetaer , softener
Stop valves in bathroom while drywalling StevePax Plumbing 11 01-17-2010 05:52 PM
shutoff valves all leaking hohadcr Plumbing 1 08-01-2009 06:38 AM
why do my 1/4 turn valves leak? moondog111 Plumbing 1 12-07-2008 11:09 PM
SEWER BACK UP, Which Flood Control Good????? diyjt5259 Plumbing 1 10-08-2008 10:44 AM
Question with wiring up a flood light. SuperAkuma Electrical 6 09-20-2008 10:58 AM
