Flood Prevention? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-22-2012, 01:49 PM   #1
Rewards Points: 876
Flood prevention?
Hi;
I have an under-the-sink water filtration system:
http://www.h2odistributors.com/insta...?i=H2O-RUS-200
The hookup I have is the same as in the diagram, except that I added a flow meter to the filter line. The filter and flow meter have plastic "John Guest" fittings.
The system has been installed for almost 3yrs without a problem, but I am concerned with the eventual failure of one of the plastic components, which will inevitably lead to a flood in the kitchen.
I am going to replace the shut-off valves with ball valves, and, at the same time, reduce the chances that something will blow in the middle of the night.
First off, I want to eliminate the short piece of tubing between the shut-off and the T with a 1/2" T that will thread into the shut-off valve, and provide one 3/8" and one 1/4" compression fitting.
I would also like to replace the plastic shut-off for the filter with a brass ball valve.
It would actually be preferable to have this shut-off separate from the main shut-off for the sink, but having it after the main would be OK too. The thing is, I want to eliminate as many of the plastic fittings as possible.
If there is an anti-flood valve that I can install in the line, that would be great, as the filter requires such a low flow that it should be easy for a valve to detect a much higher flow.
Here is a photo of the hookup I now have:
Any thoughts/advice?
FW
Ultrarunner2017 is offline   Reply With Quote
Old 02-22-2012, 04:21 PM   #2
Rewards Points: 636
ok so do you know how long john guest has been around over 50 years in business and these fitting are used all over in the restaurant business some in some very large and expensive coffee shops and i have never heard of one failing
so in my opinion why change something that has a good reputation
http://www.johnguest.co.uk/Home/appl...alves-(1).aspx
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 02-22-2012, 06:03 PM   #3
Rewards Points: 876
http://www.johnguest.co.uk/Home/applications/beverages-and-drinks-dispense/Valves/Acetal-Stop-Valves-(1).aspx
Thank you for that info. I wasn't familiar with John Guest's reputation.
I like this kind of answer... it basically tells me I don't need to make work for myself. I guess when I installed the filter, I attached everything properly (followed all of the instructions), or I would have had a leak by now.
So I guess the only thing I will change is the main shut-offs, since they are so old and almost impossible to use, and leak (from the stems) when disturbed.
I already have the ball valves for that job.
FW
Old 02-22-2012, 10:56 PM   #4
FW,
While your changing your stops under the sink you might want to consider changing the supply lines to your sink from the current gray chrome(?) ones to the braided stainless steel ones similar to the one you have for you pull out faucet. Just a thought as they are more flexible (forgiving) than the rigid ones you currently have in place.
Also I used to install under the counter RO's a few years back, using John Guest fittings, and never had a call back due to a fitting releasing (blowing off).
VIPlumber is offline   Reply With Quote
Old 02-23-2012, 06:38 AM   #5
Rewards Points: 876
Originally Posted by VIPlumber View Post
FW,
Those gray tubes are integrated into the Delta faucet. I may need to change that out as well, as it has not been performing up to my expectations.
FW
Tags
anti-flood , plastic compression
Flood prevention - need ideas tommy83 Building & Construction 5 09-25-2011 06:25 AM
Flood prevention - need ideas tommy83 General DIY Discussions 10 09-23-2011 01:08 PM
Wiring 2 Motion Sensor Flood Lights Through Siding Datwood2009 Electrical 3 05-15-2010 10:16 AM
Question with wiring up a flood light. SuperAkuma Electrical 6 09-20-2008 10:58 AM
