Old 02-22-2011, 04:01 PM   #1
Question
Flood Control Valve Removal or Access (Bozy Valve)
I am working in my home and we need to access this valve to power-rod the sewer line but the only access we have is opening this valve which is about 20 years old and we can't seem to get this removed. Can you let me know how we get this out so we don't damage this. It is about 25 years old photo attached. We have already removed the 4 main bolts but not sure if the others shown also need removed. ANY help APPRECIATED!
catfishmk is offline   Reply With Quote
Old 02-22-2011, 10:57 PM   #2
that valve is supposed to be serviced and greased every year. If you can't pull it out (use a big hyd. jack) then a floor break is in your future. Is this valve in SE Michigan?
plumberinlaw is offline   Reply With Quote
Tags
bolt removal valve
Replace a shower valve with no access panel ALfromSTL Plumbing 11 12-12-2008 09:56 AM
SEWER BACK UP, Which Flood Control Good????? diyjt5259 Plumbing 1 10-08-2008 11:44 AM
Taco Valve Control Head Repair, or Replacement? s0lidgr0und HVAC 3 10-08-2008 12:10 AM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 12:16 PM
moen valve cartridge removal pipeguy Plumbing 1 02-26-2005 12:13 PM
