Flexible Yellow Gas Piping - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-02-2011, 09:46 AM   #1
What are the limitations on the use of flexible yellow gas piping? Can it be concealed above hung ceilings or in soffits? If so what code required protection against penetration by a nail or screw?
fbarber is offline   Reply With Quote
Old 11-02-2011, 10:48 AM   #2
Rewards Points: 320
The limitation is the yellow piping it's self. It is easily punctured and also prone to fires. I'd avoid using flex pipe if you can.
autx790 is offline   Reply With Quote
Old 11-02-2011, 10:48 AM   #3
Rewards Points: 320
The limitation is the yellow piping its self. It is easily punctured and also prone to fires. I'd avoid using flex pipe if you can.
Sorry, double posted
Old 11-02-2011, 07:18 PM   #4
Flex pipe can be concealed in hung ceilings or soffits. As for penetrations, just like copper, it must be 1.75" from the wall or ceiling surface, otherwise a strike plate must be used where that depth cannot be achieved. As for it being "prone to fires", just be sure that it is bonded to ground. This was the issue from a few years ago: some houses were hit by lighting and the flex pipe melted due to it absorbing all of the electrical energy; fires ensued. Bonding, as all metallic gas piping should be, eliminates this threat.
hvac benny is offline   Reply With Quote
Old 11-03-2011, 07:17 AM   #5
Rewards Points: 320
I know the manufacturer is attributing the fires to improper bonding, but if that was the case they wouldn't be modifying the materials they use and supply houses wouldn't be pulling it from their shelves. Even when bonded as a gas line should be, it still has faults and is the cause of fires.
Old 11-03-2011, 08:36 AM   #6
Care to back any of this up with a link, source or at least some sort of cognizant rationale behind your assertion that flex pipe "is the cause of fires"?
Old 11-03-2011, 11:29 AM   #7
Rewards Points: 1,062
Question
what is the maximum length flex pipe can run? my stove is about 6-7" away from where i'd like to stop running black pipe (complicated to explain but tight areas and too much demolition and reengineering would be involved in breaking way for stiff pipe). am i safe to go with yellow flex pipe?
Old 11-03-2011, 07:41 PM   #8
Flex pipe, like all gas pipe, must be sized according to it's pressure, longest run, and load. Probably best to get a pro to do this for you.
Old 11-05-2011, 07:58 AM   #9
Thanks for the responses. All are helpful.
Old 11-05-2011, 08:00 AM   #10
Old 02-24-2013, 09:46 PM   #11
I have a install in my shop where this yellow flex was apparently run from te house through PVC pipe to shop.
Upon exiting the PVC at the stud wall treated plate the yellow fle goes up vertical stud wall and runs horizontal
amongst attic trusses toward upstairs rear furnace closet.
In the middle of this horz truss run the yellow line is TEE'd with a brass fitting. I cant (yet) see close up to brass tee
but off bottom of tee is black iron pipe going down through sheetrock ceiling and ultimately supplying hung
REZNOR unit heater.
I now want to Tee again and supply a water heater which would be down at slab level (13' ceiling)
How can I make arrangements to purchase and run more of this yellow hose in between vertical studs down to where a
new water heater will be placed ??? OR will you suugest/insist that I use hard blk iron pipe to supply
the water heater???
Thanks Chuck
Auburn, WA
CamarosRus is offline   Reply With Quote
Old 02-24-2013, 09:55 PM   #12
Plumber
TheEplumber's Avatar
Rewards Points: 684
Sounds like Tracpipe or similar product. You need special tools and certification to work with it.
You would also need to do sizing calcs to confirm the existing line is sized properly to handle the additional load
Old 02-24-2013, 09:57 PM   #13
Rewards Points: 13,750
Camaro, go back and add your own post not just add onto someone elses.
To confusing.
amakarevic (02-24-2013)
Old 02-24-2013, 10:07 PM   #14
Maybe I'll contact the Gas Utilty company or water heater vendor.
Why has my white paint work turned yellow S. Alton Painting 6 07-07-2011 11:52 AM
Insulation under staircase...yellow dust?? CanRulez Insulation 0 03-20-2011 08:35 PM
Piping Layout for New Bathroom structman Plumbing 2 02-23-2010 05:24 PM
Flexible copper piping proofer Plumbing 4 05-17-2009 08:35 PM
Flexible propane piping shvizdak Plumbing 2 10-27-2007 06:37 PM
