Old 12-28-2008, 03:53 PM   #1
Lightbulb
Flexible vent pipes?
I'm in the process of installing 'can'/recessed lights in my kitchen. I cut a hole for one of the csans and found a vent pipe directly above the hole.
Can I cut the vent pipe and add a flexible pipe/hose to get around the can?
Rob H is offline   Reply With Quote
Old 12-28-2008, 06:32 PM   #2
Whatamess
If it is a sewer vent you will need to reroute it with pvc. No flex pipe.
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 12-28-2008, 07:36 PM   #3
It appears to be a kitchen sink drain vent - it this considered a 'sewer' vent?
Old 12-28-2008, 10:07 PM   #4
Whatamess
Yes and you should be able to reroute it with pvc.
Old 12-28-2008, 11:49 PM   #5
Moderator
Termite's Avatar
It would have to be re-routed with PVC. There are no flexible options unfortunately.
Old 12-29-2008, 06:02 AM   #6
JDC
Plumbing Contractor
JDC's Avatar
Although there is 1-1/2", 2" and even 3" flexible PVC out there, it isnt approved for drain, waste and venting. Some 45s, a little bit of pipe and time though and you'll be home free.
JDC is offline   Reply With Quote
Old 12-29-2008, 07:40 AM   #7
Before you tear down the ceiling to re route, if you're lucky you may be able to offset up diagonally or sideways a few inches by using a couple of 45 degree elbows with a 2-6" stub between them. Don't try to swivel or push your pipe sideways since you may crack a hidden joint down line and cause more work for yourself. Also remember to keep your pvc away from the future heat of your light pots.
Chemist1961 is offline   Reply With Quote
Old 12-29-2008, 08:55 AM   #8
Moderator
Termite's Avatar
There is no clearance requirement between DWV pipe and can lights, but it would be a good idea to maintain a little space for good measure.
Also, when you re-plumb, don't accidentally create a point to prevent water from passing or a point of accumulation. Any new plumbing should be level with the pipe's flow.
Bubbling in toilet rballard Plumbing 11 08-30-2008 08:15 PM
Low-Slope Ventilation - Cobra Fascia Vent and Cor-a-Vent Roof-2-Wall vent atulc Roofing 7 08-22-2008 11:40 PM
Plumbing Vent size recommendations rlhed Plumbing 4 07-31-2008 01:01 AM
Extra high vent pipes? fw2007 Plumbing 6 07-11-2008 09:07 AM
Flexible gas line and dryer vent? kcrossley2 Plumbing 5 05-05-2008 12:31 PM
