-   -   Flexible vent pipes? (http://www.diychatroom.com/f7/flexible-vent-pipes-34557/)
Rob H 12-28-2008 03:53 PM
I'm in the process of installing 'can'/recessed lights in my kitchen. I cut a hole for one of the csans and found a vent pipe directly above the hole. :oops:
Can I cut the vent pipe and add a flexible pipe/hose to get around the can?
TazinCR 12-28-2008 06:32 PM
If it is a sewer vent you will need to reroute it with pvc. No flex pipe.
Rob H 12-28-2008 07:36 PM
It appears to be a kitchen sink drain vent - it this considered a 'sewer' vent?
TazinCR 12-28-2008 10:07 PM
Yes and you should be able to reroute it with pvc.
Termite 12-28-2008 11:49 PM
It would have to be re-routed with PVC. There are no flexible options unfortunately.
JDC 12-29-2008 06:02 AM
Although there is 1-1/2", 2" and even 3" flexible PVC out there, it isnt approved for drain, waste and venting. Some 45s, a little bit of pipe and time though and you'll be home free.
Chemist1961 12-29-2008 07:40 AM
Before you tear down the ceiling to re route, if you're lucky you may be able to offset up diagonally or sideways a few inches by using a couple of 45 degree elbows with a 2-6" stub between them. Don't try to swivel or push your pipe sideways since you may crack a hidden joint down line and cause more work for yourself. Also remember to keep your pvc away from the future heat of your light pots.
Termite 12-29-2008 08:55 AM
There is no clearance requirement between DWV pipe and can lights, but it would be a good idea to maintain a little space for good measure.
Also, when you re-plumb, don't accidentally create a point to prevent water from passing or a point of accumulation. Any new plumbing should be level with the pipe's flow.
