Flexible Tubing To PVC Fitting/adapter - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-25-2011, 02:33 PM   #1
flexible tubing to PVC fitting/adapter
Hey fellas. New member here. I am installing a homemade livewell in my Jon boat, but I have a little bit of a problem. The outlet on the pump requires using 3/4" inside diameter flexible tubing and a ring clamp, but I want the majority of my plumbing to be done in PVC for durability reasons. I would like to use a few inches of flexible tubing coming from the pump, and then transistion into PVC. How can I adapt from the flexible tubing to PVC? I drew a quick sketch of what I am envisioning in my head, and I tried looking at the Home Depot for something like that, but I didn't see anything. So...what do I need to do?
Thanks!
tripleup05 is offline   Reply With Quote
Old 01-25-2011, 02:58 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,058
Ayuh,... Due to vibrations, 'n whatnots, the flexible tubing is used on boats for a Reason...
It holds up Much Better than glued pvc....
Old 01-25-2011, 04:28 PM   #3
Lightfoot's Avatar
Rewards Points: 272
Take the pump with you to your local plumbing supply place or hardware store, tell them what you're trying to accomplish, and i bet they come up with something that will work. It's always easier to explain what you need when you have a part of the project in front of you
Lightfoot is offline   Reply With Quote
Replacing Solid with Flexible Sink Supply Line LeviDIY Plumbing 8 05-19-2012 05:36 PM
Copper tubing for icemaker? BigJimmy Plumbing 15 09-11-2011 02:23 PM
Is 1/2" PEX tubing enough? Homerepairguy Plumbing 12 12-24-2010 04:52 PM
How tight for Poly tubing? Ultrarunner2017 Plumbing 4 03-26-2009 07:41 AM
What is PEX-a tubing and can I use Push-N-Turn with it? curls00 Plumbing 2 07-31-2007 10:05 PM
